02-11-2014, 08:35 PM | #1 |
White stuff in my oil
02-11-2014, 08:40 PM | #2 |
Re: White stuff in my oil
I've never seen coolant or water in the oil turn white but maybe it does in rare occasions?
02-11-2014, 08:56 PM | #3 |
Taste it, does it taste sweet, its antifreeze.
02-11-2014, 09:10 PM | #4 |
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
Pretty sure that that is water. Either way, water or anti-freeze, I'm pretty sure it ain't s'pose to be there.
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY! IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE! |
02-11-2014, 09:13 PM | #5 |
Interesting
02-11-2014, 09:35 PM | #6 |
I had the same problem x100. started having problems and started to pull the motor down. Rocker covers were filled with a thick white grease like substance. My newly purchased so called re-co'd motor had a cracked crank. cracked head, HV oil pump and standard sump, and a heap of other problems. I'm told that a sign of water in all is the oil looks cloudy. a lot of water in oil is the oil looks milky. so a TON of oil in water must mean the oil turns to thick white grease. That's been my learning curve
02-11-2014, 09:42 PM | #7 |
I'm not seeing a lot of white, is the oil itself white? Is it just built up in the valve cover? Water will turn the oil white but the oil puddled in your rockers looks fine. Could it simply be condensation?
http://smg.photobucket.com/albums/v655/aaronhero/ |
02-11-2014, 09:50 PM | #8 |
Does the truck sit out? We are in a high humidity locations both you and I. Even though it is like 15 degrees out right now I've seen this in several motors I had on some of my "toys" that rarely get use and sit more that they go. I always have such a fit to build the darn things then I drive them a couple of times[if that] and then I am through with then like an exgirlfriend or something that I had rather not deal with any more. One more question do you have one of those open breathers that go in the valve cover? I still think it is a tiny bit of moisture not of any doing of the trucks motor but of the weather around it. Unless your running it on alcohol then if you've got 50 miles on it your way clean and over due an oil change. Jim
02-11-2014, 10:10 PM | #9 |
What does the oil it self look like if its just yhe covers it from not heing run long enough to burn off the condedtion
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
02-11-2014, 10:34 PM | #10 |
I would guess condensation from blow-by? See it on pcv valves up here in cooler months frequently
02-11-2014, 10:44 PM | #11 |
Aluminum valve covers and intake, my guess is aluminum oxide (aluminum's version of rust) Don't know if it is damaging or not.
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
02-11-2014, 11:28 PM | #12 |
looks like condensation to me, caused by short trips in cold weather not getting the engine warmed up.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin 67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts) |
02-11-2014, 11:45 PM | #13 |
Condensation. Start letting your engine get up to temp before going anywhere on cold days. Gives the moisture a chance to cook off, and saves your bearings, the moisture will mix with the oil at idle, but if it cooks off before you put it under load, it will be ok. You can also try an oil heater at night to see if that prevents it.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast! Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun. 1st BN 3rd MAR. '00-'04 |
02-12-2014, 12:15 AM | #14 |
I've seen that too from engines that sit for periods. Especially with aluminum valve covers
02-12-2014, 12:27 AM | #15 |
Use a sock ....I like my truck too.
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. " |
02-12-2014, 01:28 AM | #16 |
Looks like condensation. Let it sit for a couple of days, pull the oil plug slowly and see if u get any water before oil, If you do you've got head or gasket problems. You can also pull the spark plugs and turn it over and see if it pumps any water out of cylinders.
02-12-2014, 01:43 AM | #17 |
I agree it could be from short trips as well. It could also be from the PCV not working/hooked up right.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
02-12-2014, 04:20 AM | #18 |
Moderator
Drain your oil. If you see it in there, it's water/coolant.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
02-12-2014, 08:59 AM | #19 |
Dont even need to drain the oil. Check the dip stick. If it looks like oil fire it up and let it run for a few minutes. Recheck the dipstick. If there is any white swirl on the dipstick or a milkshake then you have a problem. As others have said a little moisture this time of year is normal. I have some in my motor also and it gets up to temp for several miles each day and takes me to work each week.
02-12-2014, 09:13 AM | #20 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-12-2014, 10:07 AM | #21 |
It has been sitting. I bought it from a guy in Idaho that I'm fairly sure left it outside. Since I have had it, it sits in my shop which remains 40 degrees or higher depending if I'm out there or not. It does have the little breathers on each valve cover, so maybe it is just condensation. When I drained the oil to change it a few days ago the oil looked normal.
02-12-2014, 10:40 AM | #22 | |
Only breathers, no PCV? That's your problem. If you need help on how to install one, just ask
http://autos.yahoo.com/maintain/repa...ques079_1.html Quote:
02-12-2014, 11:05 AM | #23 |
Thanks. I go buy one today after work and install it.
02-12-2014, 11:22 AM | #24 |
Be sure to leave one of the breathers (the crankcase needs to be able to suck in clean air).
02-12-2014, 12:00 PM | #25 |
Do you warm your truck up before draining the oil when you change it? That condensation can build up over time. I'd get the truck as warm as you can,go out and run the pizz out of it,then drain oil...carefully!
