Old 02-12-2014, 01:13 PM   #1
61K10
61K10's Avatar
dana44 5f closed knucle
while rebuilding my 61 D44 i found that some of the ring gear bolts were loose and 2 were missing but i only found 1 in the bottom of the case. there is nowhere for one to hide that i can see. I guess some one was in here at one time? ring and pinion look fine as not all of the bolts were loose. x-pin bolt is broke also. anything else i should look for?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
