Old 02-12-2014, 03:11 PM   #1
jks67ss396
Vintage Air Evaporator Leak Test
Guys
Is there anything i can do to test the evaporator for leaks before having my system charged for the first time? Ive heard some guys pressurize the system with compressed air. I know that introduces moisture, but the thing will be vacuumed out when its charged anyway.
i just want to test the evaporator so i minimize the chances of having to pull it out once the system is charged (ie slow leak or something)
Any ideas?
thanks!
jks67ss396 is offline   Reply With Quote
Old 02-12-2014, 03:21 PM   #2
engineer_gregh
engineer_gregh's Avatar
Re: Vintage Air Evaporator Leak Test
I'm not sure but I would think a vacuum test would accomplish the task. Question is, can you do a vacuum test on just the evaporator? I'll refer to smarter people than myself.
engineer_gregh is offline   Reply With Quote
Old 02-12-2014, 03:24 PM   #3
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
When you loosen the caps if it relieves pressure you want have any leaks..
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 02-12-2014, 03:36 PM   #4
BMERDOC
BMERDOC's Avatar
We use nitrogen for diagnosis. The shop will put a vacuum on the system before charging it so if they have any sense they'll pause before charging to make sure the system is leak free.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 02-12-2014, 03:44 PM   #5
jks67ss396
Hey screaminchevypickup (i bought it from Sarah)
I really want to test the lines that screw into the evap. they seal with o-rings. thats what i want to test... pain in the butt to pull it back out or expensive if the shop does it
Nick or anyone else,
I have hoses that screw into the evap that are unterminated on the other end. so maybe hose clamps to compressor hardline??
Is there anything wrong with using compressed air if i get it evacuated later???
thanks!!
Old 02-12-2014, 05:07 PM   #6
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Most shops vacuum it and wait to make sure it'll hold a vacuum. If it won't hold vacuum it won't hold pressure.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Ol Blue K20 is online now   Reply With Quote
Old 02-12-2014, 05:16 PM   #7
mcbassin
Still Learning
mcbassin's Avatar
I like to pressure the system with Nitrogen up to 100-150 psi. I wouldn't recommend using compressed air if you can avoid it. It will have moisture in it.
Then pull a hard vacuum for a few hours. I use a digital manometer to see if it holds vacuum before charging with Freon.
I would be willing to bet Vintage air already did a pressure test with nitrogen.
mcbassin is offline   Reply With Quote
Old 02-12-2014, 05:53 PM   #8
fattyarbuckle
vacuum to 500 micron, isolate system with pump shut off, if it holds there for 24hrs, there isn't a leak or moisture...
I've never heard of a manometer for vacuum.
fattyarbuckle is offline   Reply With Quote
Old 02-12-2014, 07:22 PM   #9
BMERDOC
BMERDOC's Avatar
We use Manometers to check crankcase vacuum. BMWs run negative crankcase ventilation.
Nick Carter
Old 02-12-2014, 07:25 PM   #10
screaminchevypickup
Laid Back
thanks!!
Every unit comes pre tested.. I wouldn't put any air in the system because like others have said you will get moisture... I've never had to pull vacuum on one of these system for more than 30 minutes..
Also thanks for the business..
Kyle
72 chevy swb
Kyle
Old 02-12-2014, 07:25 PM   #11
fattyarbuckle
LOL^^^
Manometer can't check inch's of vacuum...they can only check a negative or less than atmosphere pressure.
Old 02-12-2014, 07:43 PM   #12
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by fattyarbuckle View Post
LOL^^^
Not sure what this means? I routinely use a very low vacuum chamber for aerospace work. To monitor differential pressure we use a manometer. If you can hold negative sustained pressure. After the pump is turned off, You won't have a leak. It's a simple tool to monitor pressure. Did I miss the joke?
I use my gauge set for reading vacuum pressure.
Old 02-12-2014, 10:53 PM   #13
jks67ss396
Kyle
Hey Kyle
Buying from you was a no-brainer. best price by far!
But, getting back to this, i understand the evap as a unit might have been tested at factory, but i put the lines on at home, and seald with o-rings.
thats what i want to test. if the orings sealed properly.
by the sound of it, ill need some fancy equipment if i cant use an air compressor, and i might as well pony up and let the shop test it. worse case, i have to pull the evap box right there at the shop and fix whats needed.
thanks!
Old 02-13-2014, 09:08 AM   #14
MARKDTN
I have always used compressed air. If you have a dryer on your compressor and pull a good vacuum you should not leave any moisture when you are done. I just put 100 psi into both sides, close the valves, and let it sit 20-30 minutes. If the needles stay put I let it out (slowly so you don't loose any oil) and pull a vacuum for 45 minutes or so and I have never had any issues. If you have access to nitrogen I'm sure that would be even better, but a good longer-than-usual vacuum should get all the moisture. A compromise might be to pressurize with shop air with an old dryer to check for leaks and change it before the vacuum and charge since the dryer media is where moisture can be captured. Then you only have 2 fittings to worry about. Won't help with your situation, but may help someone with a stock system.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
