Old 02-12-2014, 05:37 PM   #1
Ozzy2013
Ozzy2013's Avatar
Doors and locks
Hi i have looked all over the forums and cant find info on door locks.My 68 doors if i push the lock buttons down or use a key they go down about a inch.But the door wont lock i do this with the doors shut and open then shut them but the lock wont stay engaged.Any hints or experience with this?Again appreciate any help thanks Oz.
Ozzy2013 is offline   Reply With Quote
Old 02-12-2014, 08:35 PM   #2
dbash
Re: Doors and locks
Are the lock stems aftermarket? Or blocking it from going all the way down somehow?
http://67-72chevytrucks.com/vboard/s...d.php?t=509467
2008 Dodge 3500 Blue Tech
2013 Challenger SRT8 392
1972 Landcruiser Rock Crawler LS1
1969 4X4 Resto Mod
dbash is offline   Reply With Quote
Old 02-12-2014, 08:36 PM   #3
Daman
Re: Doors and locks
Every one I have had, you have to use the key to lock them
Daman is offline   Reply With Quote
Old 02-12-2014, 09:22 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Re: Doors and locks
You would be correct. You can't push the button down or lock it with the key and then close the door. The button will pop back up. It is a safety feature so you can't lock your keys in the truck...
LockDoc
Leon
Old 02-12-2014, 10:38 PM   #5
midniteblues
midniteblues's Avatar
Re: Doors and locks
LockDoc
when i built the kids 67 i fought with this for weeks till i gave up. then a good while later i read this from you in another thread an i thought too myself all the time i wasted tryin too fix'em
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 02-12-2014, 11:01 PM   #6
Molberg
Molberg's Avatar
Re: Doors and locks
My locks would only partially engage after I replaced my weatherstripping. If I pushed in on the door lightly(from the outside) ... I could lock it with the key. Adjusted the striker plate out a hair. Fine now.
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 02-12-2014, 11:27 PM   #7
LockDoc
LockDoc's Avatar
Re: Doors and locks
You aren't the only one so don't feel bad...
Yes, that usually works, and sometimes after a while you can adjust them back in a little.
LockDoc
Leon
Old 02-13-2014, 01:14 AM   #8
1970/327/c10
1970/327/c10's Avatar
Re: Doors and locks
I have that problem but i just mess with the key until it locks the door.
Drivin People Insane With my Classic Chevy!
1970/327/c10 is offline   Reply With Quote
Old 02-13-2014, 03:43 AM   #9
Ozzy2013
Ozzy2013's Avatar
Re: Doors and locks
My door lock stems are stock i can take them off and it makes no difference.With the door shut you push them down while in the truck they dont lock.With the door shut the key will move the lock stems down .Remove the key push it the door button and the door opens not locked!So..............
Old 02-13-2014, 03:46 AM   #10
Ozzy2013
Ozzy2013's Avatar
Re: Doors and locks
I will try moving the strikers out some next .Thanks guys love this sight everyone is very helpful .What a great resource!Oz
Old 02-13-2014, 07:56 AM   #11
serge
serge's Avatar
Thumbs up Re: Doors and locks
LockDoc
Did not give it much thought but what you say makes sense. Thanks for sharing that info.
serge is offline   Reply With Quote
Old 02-13-2014, 10:48 AM   #12
LockDoc
LockDoc's Avatar
Re: Doors and locks
Also roll the window down and spray some penetrating oil on the back of the lock and on the latch. You can see down in there pretty good with the window down, if you use a good light.
LockDoc
Leon
Old 02-13-2014, 11:27 AM   #13
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Doors and locks
You also can't lock yourself inside the truck. If you lock the door then use the inside door handle to open the door, it will pop up 100% of the time. The lock only locks the outside door handle.
Lock it with the door open, then see if you can push in the outside door button with the door still open. If not, there is something up with the lock mechanism. If it does lock, you have an adjustment/striker issue.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
