![]() Join Date: Dec 2013
1972 GMC SEIRRA GRANDE options SPID
maybe you guys can assist me , im kinda new hear and im a old fart learning , I cant quite tell if this truck ive aquires , has all of the right stuuf or some has been changed , ill try and post a couple pics also , here goes its white and olive , seira grande , has the parchment trim package , and the sierra grande , if I understand the grande package is like the Cheyenne super , my questions , are 1. should this have the wood grain inst bezel,
2 does it have the righ seat belts, and dash pad they are black 3 is the glove box door supposed to be black 4 the ash tray has wood on it and my Cheyenne dosnt is this correct , I know things change thru the years just like we do , sorry for the bad spelling and such but we are like are trucks and have flaws , thanks for this wonderful site for knolwege , no go easy on me , let me have it , im going to try and post pics with this thanks, kevin |
![]() Join Date: Oct 2011
Hey Undertaker...here is a bit of feedback.
First....very nice truck!! Second, your truck has had some great updates...including the addition of the factory tach. When this was done it appears as the original (woodgrain) bezel was replaced with a newer all chrome (plastic) one. So...looks great, but it isn't original if that matters? I'm not sure about the glovebox tho'....GMC did things a little different than Chevy so they 'might' have painted it black but the tell tale would be if the vin number on the inner spid matches your main vin plate, etc. That would probably indicate 'yes' it is original to the truck. I'm not sure if the seatbelts should be black tho'. If you have the parchment trim ordered the seatbelts should be parchment too....at least I'm pretty sure about that. The ashtray thing...I'm not sure if this was added later or not. Ok, that should get things started.... All Good Coley ![]()
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
Re: 1972 GMC SEIRRA GRANDE options SPID
that's kinda my thinking, I thought it should have the wood grain , and like you stated , gmc is a little different , I kinda recearched and read the sierra grande package came with the tilt and tack and this has it , it has posi and everthing else matches , and the vin in door matchs and its never been altered , its still attached with the roset rivets , thanks for the help kevin
Moderator
![]() Join Date: May 2007
Tilt and tach are stand alone options that would be called out on the SPID. Someone added these to your truck. It's no biggie if they weren't there originally, they are there now and nice to have.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#5 | |
![]() Quote:
Some of the other guys will weigh in on this I'm sure to help clarify a little further. If the truck came with Tilt and Tach it would be on the option plate (aka 'spid')...it wasn't part of a hidden option package, Sierra Grande or Cheyenne Super...they did still need to be ordered to be included...and they would show on that (spid) sheet in the glovebox. Regardless....you have them! so that is the important point and no worries, a lot of guys look to add those options at some point. Does it have a 'psi' gauge? If so, that too is an indicator of it coming from a donor truck. The psi gauge usually came out of the big 3 and 5 ton trucks for the air brakes and wasn't available (or needed) on the smaller trucks. A lot of guys like them tho' who are adding the air bag options, etc...nice to have!! One 'give away' on the factory tachs is if the needle colour exactly matches (...or not) the other gauges in color and fade. Again...nice truck! All Good Coley
yes I see what you are saying , and mine is faded thanks you guys
The black belts are correct for what you have. I have a red and white super that has parchment interior, black dash pad, black belts. Tilt and tach have been added at some point and the glove box door is correct, some plants used black doors on grandes and supers- think it was St. Louis plant but not positive. Nice truck!
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
GMC with Blue Plaid
Different than Chevy GMC color matched the glove box doors with the instrument bezel and dash pad. So since your dash pad is black your glove box door is also black. Nice Truck, you should post more pics.
Current: 1972 GMC Super Custom 1500 402 < 73K Orig MI 2015 GMC Canyon SLT(Daily Driver) Previous: 2008 Chevrolet Colorado LT 2.9L I4 1988 Chevrolet Suburban Silverado 10 350 < 60K Orig MI 1984 GMC S-15 2.8L V6 1976 GMC Sierra Classic 2500 Camper Special 350 1980 GMC High Sierra 3500 Dually 350 4spd 1974 Chevrolet Cheyenne Super 10 Shorty 454 (Was my Dads, I wish I still had it) 1969 GMC 910 250 I6 4spd |
thanks as the weather permits , its kinda snowy now , but ill post some thanks again
Wood grain on ashtray is after market.
Overall it looks pretty good. The black trim items are correct including the carpet. The black seat belts are probably correct considering it has black A/C vent balls ( easier to live with too). However that seat cover is a real deviation from stock. The factory cover would have been parchment/white vinyl with black and white houndstooth inserts. Yours appears to be an incorrect olive houndstooth. The vinyl cover should be covering the the seatback side arms. The woodgrain should be on the door panels, glovebox door and gauge bezel. The ash tray was never correct with a wood applique. Finally the steering wheel should be black plastic as well. Except for small detail differences it will be the same as the 71 and 72 Cheyenne Supers pictured.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#12 | |
ss tim , thanks for the info , and enclosed pics |
#13 |
![]() Join Date: Sep 2005
I also have a 1972 Sierra Grande. I am including a picture of the SPID. Ochre and white truck with parchment trim. My truck has the seat belts, dash pad, carpet and glove box door in black. The glove box door had the woodgrain cover, but the door itself is black. Interestingly, the SPID shows the GMC truck as having "Cheyenne Super Equip". I believe this is also fairly common depending where the truck was built.
James |
#14 |
jlmerie, that's interesting , and I guess like you and a couple others have said it could vary from plants , and heck maybe the day its built thanks, kevin
#15 |
![]() Join Date: Feb 2001
undertaker72 ...
Let me say this. I would not kick your truck out of my garage. Its a very nice truck ![]()
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#16 |
Actually that is very common to see YE9 Cheyenne Super on a GMC SPID. Sometimes there is a GMC conversion listed too. It also seems that St. Louis had a lot of variations over the years in SPID format and descriptions, more than most plants. Found another parchment with black in my collection this morning. It is a 71 Chevy and does not have the black door but still gives a very good feel.
