Old 02-12-2014, 09:56 PM   #1
Lugnutz65
Lugnutz65's Avatar
Small WIDE back window. Dumb idea - or could it work?
I like the big back window trucks. However, I don't have the fabrication skills to do the BBW conversion.
If this idea is dumb, please just say so. I want honesty. Don't patronize.
Look at the pics below. I photoshopped the 2nd pic. It is NOT a BBW but rather a small back window made WIDER. In my mind, the fab work would be much easier and finding a donor would be very easy because SBW trucks are so common.
I want some folks with fab skills to give some input on this.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 02-12-2014, 09:58 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Small WIDE back window. Dumb idea - or could it work?
It's the curve on the inside panel that will limit the small window stretch.
Old 02-12-2014, 10:00 PM   #3
Lugnutz65
Lugnutz65's Avatar
Can you explain more?
Here's the inside and the inner wall curves at the corners. Maybe it could be widened but not as wide as I made in my photoshop version?
Old 02-12-2014, 11:09 PM   #4
corvettejim1968
corvettejim1968's Avatar
im not sure if you are aware you can buy a conversion kit like mine. it was just under $500
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 02-12-2014, 11:31 PM   #5
63burban
Chevy addict
Paint the panel around the small window black or charcoal ?
63burban is offline   Reply With Quote
Old 02-12-2014, 11:54 PM   #6
sigshooter
sigshooter's Avatar
Check out my build thread, I am doing the conversion now. It will be much easier than trying this.
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 02-13-2014, 02:20 AM   #7
theastronaut
theastronaut's Avatar
That would require two donors, then fitting and butt-welding the panels into both the inner and outer panels- lots of fitting, welding, grinding, and bodywork to get the weld seams right. A factory BBW donor would only require spot welding around its edges- no grinding or bodywork needed. The outer panel is cut but no fitting/butt-welding has to be done, only spot welded around the pinchweld for the outer panel.
Another consideration is that the tapered upper roll around a small window's opening would be tough to get right when welding two pieces together; fitting them would be fine but the taper from narrow at the edges to wider in the middle wouldn't look right. You'd have to fab a new rolled upper edge with an even taper side-to-side so it would look right. Even if you did it the wide small window, the height wouldn't match the other windows so the proportions would be off.
theastronaut is offline   Reply With Quote
Old 02-13-2014, 02:36 AM   #8
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
To me it's an interesting look, but I don't see it being necessarily less fab work than just doing a full bbw conversion.
66 C20 Service Truck:
Old 02-13-2014, 08:33 AM   #9
corvettejim1968
here are some pictures from my conversion
Old 02-13-2014, 09:30 AM   #10
Lugnutz65
Lugnutz65's Avatar
I'd like to thank everyone for the input. My lack of experience is showing. The BBW conversion looks like something I'll leave for those more experienced than me. I need to get some practice time with a welder before I take on any big challenges like the BBW.
Thanks again.
Old 02-13-2014, 09:50 AM   #11
wayno
To me its the cutting that's tricky - the welding if you have a mig is not that difficult to get decent at - it's not like laying a bead on a frame - it's spot weld and move and spot and move... you could definitely handle that part. Easier than you think... just can't use a stick welder which is where some people go wrong - mig or tig and you be surprised how good you get quick - no bs. Good luck with your build.
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 02-13-2014, 10:07 AM   #12
racecougar
racecougar's Avatar
Could you post a link to said kit?
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 02-13-2014, 01:52 PM   #13
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I like the look that you created of the small window widened... that said it would be 10X the fab work to do that , instead of just doing the stock bbw conversion... some on here have even done the conversion without having to re-do the paint.
Old 02-13-2014, 02:40 PM   #14
corvettejim1968
http://classicbigwindow.com/
it looks like it is $499.99 now
Old 02-13-2014, 02:56 PM   #15
racecougar
racecougar's Avatar
Thanks. I hadn't seen that kit/method before.
Old 02-13-2014, 04:07 PM   #16
cortcomp
cortcomp's Avatar
The kit looks cool, but you'll have work blending those side panels in to look good inside.
With some panel adhesive and a cheap spot welder, you could knock out the bbw conversion in a weekend with no welding skills. food for thought.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
