02-12-2014, 10:08 PM | #1 |
Converting A/C to R134
I've read up on the conversion as far as what needs to be replaced. Sounds like I can reuse the evaporator coil as long as it's thoroughly flushed.
I currently have it off the truck (reassembling after a 6+ year restomod), so is that something that should be done now or when the truck is assembled and ready for a charge or ???
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73 67 Chevelle SS Clone 454/TH400/3.73 |
02-12-2014, 10:58 PM | #2 |
Re: Converting A/C to R134
IMO i would wait until all together to flush any dust or dirt that could be in the system or condensation. just my 2 cents
02-13-2014, 08:50 AM | #3 | |
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
02-13-2014, 09:55 AM | #4 |
While not recommended by car manufactures, others have claimed success using Easter oil instead of PAG.
PAG will eventually ruin non barrier hoses.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
02-13-2014, 10:48 AM | #5 |
Old member
I would wait until you are ready to do the final assembly and do a retro mod change as I did. Mine looks all factory except I used a late model compressor. I used all the new condensor, acumaltor, dryier and no sight glass. It works great and the newer tubes let the 134-a expand better and work more efficiently.
This is it today!
02-14-2014, 09:40 AM | #6 |
All good info. Thanks to all!
Time to start assembly.....
