Old 02-13-2014, 03:41 PM   #1
JJSimon904
My 71 has leaf springs AND coilovers
Hi, I just started my first restoration 1971 GMC 1500 long bed and was surprised at how well it rode right off the bat. Someone changed out the 5 lug rear end with a 6 lug 12bolt. It also has leaf springs with coil overs. I've attached a picture of it. I've done a little research and found that trucks came with one or the other, but not both as far as I can tell. Has anyone come across this before? I eventually want to drop the truck 2/4 but not sure where to begin with a setup like this.
Thanks ahead of time.
JJSimon904 is offline   Reply With Quote
Old 02-13-2014, 04:59 PM   #2
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Re: My 71 has leaf springs AND coilovers
None of these trucks came with coilovers... They only came with coils or leafs. Looks like PO put them on in place of shocks... Maybe to assist?
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 02-13-2014, 05:02 PM   #3
Sicklajoie
The Niner
Sicklajoie's Avatar
Those coil overs are obviously aftermarket.
There's a difference between that and the coil spring/truck arm setup that's on a lot of these trucks.
Pictured below:
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 02-13-2014, 05:07 PM   #4
hugger6933
Those are aftermarket shocks with a overload coil assist spring or some shock companies call them coil overs but they are not the same type coil overs we know and love. From what I have gathered, GMC's had leafs standard and coils optional and Chevrolets the other way around. Welcome to the board there is a lot of truck knowledge here so enjoy. Jim
hugger6933 is offline   Reply With Quote
Old 02-13-2014, 05:22 PM   #5
JJSimon904
Thanks for the responses. It being a helper coil makes sense. I don't plan on doing hauling anything that would require such a setup. When I do drop it, I will switch to a good shock and drop it with blocks or shackles.
