![]() Join Date: Sep 2013
Caliper help !
Re did my front brakes.. New rotors calipers and pads.. Left side went on great nice and snug , moves side to side , wheel turns nice. Right side caliper very tight,no side to side movement and wheel turns too tight. Is it ok to grind the caliper or rotor to free it up a bit. Thanks Rick
Old member
Did you press the calipor piston in all the way on that side?Did you bleed the brakes afterwards to equalize the lines just incase.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Caliper help !
Im not that far along, need to run new lines, I didn't think I needed to depress piston on new caliper.. Looks like it's in all the way .. I will give that a try thanks.. The calipers not moving side ways
Re: Caliper help !
Make sure the pistons are pushed in and the pins are lubed. You shouldn't need to turn a rotor to fit pads.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
Old member
Did you check the slides on the right side? They could be sticking and not allowing the movement. I also agree shouldn't have to grind anything with new stuff.
