Old 02-13-2014, 07:26 PM   #1
brokestudent
Whats the cause?
Ok so if you notice my post earlier the truck broke down today. I let the truck sit and then start it up and it purrs perfectly then I start having the same issue again pull over and it was making this noise
Did the same thing earlier too. I am thinking oil pump going out since it takes a while to start doing this? I check the oil and the level is fine I just had an oil change etc so I am at a loss here guys.
brokestudent is offline   Reply With Quote
Old 02-13-2014, 07:37 PM   #2
tincan1966
tincan1966's Avatar
Re: Whats the cause?
That's a whole lotta rattlin' going on!. This is merely a guess, but sounds like the rod bearings are going out. Possibly time for a rebuild.
I strongly recommend NOT driving it, until it can be properly diagnosed.
tincan1966 is offline   Reply With Quote
Old 02-13-2014, 07:38 PM   #3
Slow Build
Slow Build's Avatar
Why are you starting a third thread on the same problem?
( http://67-72chevytrucks.com/vboard/s...d.php?t=616466 )
( http://67-72chevytrucks.com/vboard/s...d.php?t=616323 )
It's better to keep all the info and replies on one thread.
Hard to tell what's knocking in the video, but it doesn't sound good.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 02-13-2014, 07:41 PM   #4
brokestudent
Was not trying to start a new thread, just that I got it running again and this noise pops into the picture. Kind of related kind of not I do not know....My issue is it does not always make this sound when it first starts up and is running it purrs beautifully. This is after like driving it for 30 minutes this starts. I can drive it around town all day but taking it out of town it does this. If it were the bearing (and correct me if I am wrong) but wouldn't it do it all the time?
Old 02-13-2014, 08:10 PM   #5
tincan1966
tincan1966's Avatar
You can always keep driving it and whatever flies out the side of the engine was the problem.
OR
if you cannot find the problem, take it someone who can.
No one can accurately diagnose vehicle problems over the internet.
Old 02-13-2014, 08:18 PM   #6
brokestudent
Wow tincan I sense some hostility in that. I was not trying to knock your advice or anything it is appreciated. I agree a rebuild is needed, and I agree that it should not be driven until done. I was just trying to see if there is something inherently wrong with this that causes this issue, something that is common etc. I am new to this engine so I was trying to see, to me it seems very odd that it does it after running for a bit but runs great until that time. Maybe I am wrong this is common I do not know
Old 02-13-2014, 08:23 PM   #7
tincan1966
tincan1966's Avatar
nope, no hostility, just being a smarta**
Old 02-13-2014, 08:25 PM   #8
brokestudent
Tin I actually am coming up to Caney, KS for a job....maybe I can bring it up to you and you can tell me what is wrong with it haha
Old 02-13-2014, 08:26 PM   #9
tincan1966
tincan1966's Avatar
there's countless threads on here about people asking advise on "what's wrong with my truck" which normally end up as a big pissing match and arguments over differences of opinions.
The truth is, as I mentioned that no one can accurately diagnose issues over the internet and especially not intermittent/drivability problems. there are too many factors that could cause similar issues.
Some take it as mean, but I am just mentioning cold hard facts.
Old 02-13-2014, 08:27 PM   #10
tincan1966
tincan1966's Avatar
C'mon up I am open Mon-Fri
Old 02-13-2014, 08:32 PM   #11
AcampoDave
AcampoDave's Avatar
You can use a wooden dowell as a stethoscope listening with your ear on one end and motor on the other. Move the dowelll around and see if you can hear anything before the noise becomes deafening. I'm thinking it's quieter at first because the oil is cold and thick. My guess is a spun rod bearing.
AcampoDave is offline   Reply With Quote
Old 02-13-2014, 08:54 PM   #12
firemanjimtfd
firemanjimtfd's Avatar
The more you run it the more damage you are doing . Drop the pan and I'm sure you will find it.
firemanjimtfd is offline   Reply With Quote
Old 02-13-2014, 09:00 PM   #13
Sharps40
Yep. Time to reengine the fleet. Park it or itll die ugly.
Sharps40 is offline   Reply With Quote
Old 02-14-2014, 09:55 AM   #14
kieth
kieth's Avatar
What engine is it ??????? the you tube video did not show up on my computer..
kieth is offline   Reply With Quote
Old 02-14-2014, 11:26 AM   #15
TJ's Chevy
TJ's Chevy's Avatar
Straight 6 Keith...Probably a 230 or 250. I watched the video...Believe me....you don't want to listen to it. Talk about a seriously ticked off engine.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 02-14-2014, 12:43 PM   #16
donthekawguy
donthekawguy's Avatar
That does not sound good. Find a cheap 350/350 on craigslist, put a brick on the gas pedal making sure you film it, swap motors and go on with life.
66 shorty
donthekawguy is offline   Reply With Quote
Old 02-14-2014, 12:56 PM   #17
Sharps40
Yep thas morin one loose rod or slappin piston. If unbuttoned before any more damage is done it'll likeky be rebuildable or for 1500 get a reman 6 or abit more an 8.
Old 02-14-2014, 02:15 PM   #18
tincan1966
tincan1966's Avatar
Not all these trucks have to have a 350 in them. These old 6's are just as reliable.
Matter of fact, I am getting ready to ditch my old worn V8(305) and go back with the inliner. And before I get bashed about it being a 305- it's just as good as a 350 and has 265,000 miles without being overhauled, just good maintenance by the previous owner of the donor.
Besides that- they rank up higher on the kewl factor. LOL!
Old 02-14-2014, 02:21 PM   #19
1963c-10
1963c-10's Avatar
Hmmmm....doesn't sound good whatever it is. Time to pull it out and apart
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 02-14-2014, 02:46 PM   #20
Sharps40
Get an I6, its ain't JAFSB, its More!
Old 02-14-2014, 04:57 PM   #21
TJ's Chevy
TJ's Chevy's Avatar
AMEN BROTHA! Preach it like it is!
Old 02-14-2014, 09:22 PM   #22
joedoh
joedoh's Avatar
sounds like miss and detonation. your gas tank is full of rust and scale. its getting pulled up to the filter where the suction is blocking the flow and the engine starts to run lean being starved for fuel. when you turn it off or it dies, the suction goes away and the rust/scale falls off the filter material. start it up and its powerful again, until the suction plugs up the filter.
clean out your tank.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 02-14-2014, 10:10 PM   #23
TJ's Chevy
TJ's Chevy's Avatar
That is a dang good point....I think I had that or something similar to that happen to me...except my engine would just die. I do hear a miss when I listen to the video.
Old 02-15-2014, 12:14 AM   #24
63burban
Chevy addict
Biggest mistake people make with an inline is running them 75mph with 4:11 or even 3:70 gears. Inlines don't like that, they eventually make noises like yours and costs a bunch to make them happy again. Just because it's running smooth at high speeds doesn't mean it's ok. I agree it's not generally a good idea to diagnose problems on the net but your engine sounds worn out. Rod bearings shot.
63burban is offline   Reply With Quote
Old 02-15-2014, 12:43 PM   #25
Sharps40
Well now . Thats an easy test. New fuel filter, clean the carb and test it from a clean one gallon jug o gas. If better purge apnd rebuild the fuel system. If not. Rebuild the motor.
