Old 02-14-2014, 09:58 AM   #1
LuckyJoe
LuckyJoe's Avatar
Full Door Panel Question
While doing the mock-up for the door panel I noticed that the very top part has quite a large space to fill between the added panel and existing removable top part. This gap is created because of the design on the top removable panel. I'm thinking that I may have to leave the removable panel off to close the gap. Has anyone left it off or just cut out the raised area? Any suggestions would be appreciated.
Thanks, Joe,
LuckyJoe is offline   Reply With Quote
Old 02-14-2014, 10:26 AM   #2
Highsider
Highsider's Avatar
Re: Full Door Panel Question
Nice blue.
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 02-14-2014, 11:04 AM   #3
Russell Ashley
Russell Ashley's Avatar
The felts at the lower window opening don't seem to keep much water out. If I were doing full panels like you are doing I would leave off the original panels that have the raised ridges, but I would use a sheet of plastic like some newer cars have to deflect any water away from your new panels. Hang the plastic so that it directs the water into the door.
Russell Ashley is offline   Reply With Quote
Old 02-14-2014, 12:47 PM   #4
OrrieG
OrrieG's Avatar
You will need to keep the part that wraps around the door strike, and maybe a piece on the hinge jamb side as a filler too.
OrrieG is offline   Reply With Quote
Old 02-14-2014, 03:43 PM   #5
LuckyJoe
LuckyJoe's Avatar
Russell, I'll will actually be using a water proof product I picked up at a local Signarama store. The Lowes hard board is just for mock-up since it's cheap and I most always screw-up a time or two. OrrieG, Yes, I thought about cutting down the steel panel but might also loose too much overall support for the arm rests. The situation may resolve it'self when use the Signarama product since it's more flexible. In any case, Russell and OrrieG I do really appreciate your input. Highsider, glad you like the color, Thanks.
Joe,
Old 02-14-2014, 08:17 PM   #6
_Ogre
_Ogre's Avatar
i left the panel in to cover the gap and fill the area around the latch.
the base for my door panel is 1/4'' plywood with a second layer of plywood cut out to match the raised bead on the oem door panel.
i waterproofed the plywood with fiberglass resin.
i cut the heck out of my door to install 07 dodge durango power windows
built up the door panel to fit my interior, hide door speakers and make a usable arm rest
fiberglassed the framework
stretched and glued vinyl over the panel
carpeted panel and upholstered arm rest
shop air compressor timer
Old 02-15-2014, 12:26 AM   #7
oldman3
oldman3's Avatar
ogre, nice job on the panel, and lots of pics with details, way to go bud...Jim
oldman3 is offline   Reply With Quote
Old 02-15-2014, 11:19 AM   #8
LuckyJoe
LuckyJoe's Avatar
Ogre, that is a lot of work and turned out nice. Must have door poppers and electric windows. I may be able to add some sort of filler strip on the back side of the panel to fill the gap. Thanks for the pics.
Joe,
Old 02-15-2014, 02:06 PM   #9
Daze57
Daze57's Avatar
good lookin panals !!!
Daze57 is offline   Reply With Quote
Old 02-17-2014, 09:09 AM   #10
4DSEVEN
4DSEVEN's Avatar
Nicely done Ogre.
4DSEVEN is offline   Reply With Quote
Old 02-17-2014, 01:47 PM   #11
Dan in Pasadena
Dan in Pasadena's Avatar
Ogre, now THAT took more fabrication chops! Well done.
Why the Durango power windows instead of an aftermarket setup? Strictly cost?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 02-17-2014, 09:58 PM   #12
_Ogre
_Ogre's Avatar
Originally Posted by Dan in Pasadena View Post
Strictly cost?
yes. as in free.
plus i just have this thing about making stuff myself.
i won't build a motor, nor a trans; been there, done that.
but i have no qualms about putting 50 hrs into door panels
and thanks. to all
giving luckyjoe things to ponder
