Old 02-14-2014, 10:16 AM   #1
Jonboy
Slots go on anything!
Trans cooler ideas
What is everyone running for trans coolers? Factory cooler, cooler in your original radiator, heat sink coolers, or anything else. I like the idea of the heat sink coolers, but afraid that might not be enough. Please post up what you are running.
(disclaimer- it is highly possible I am really overthinking pretty much every step of my swap. When I actually get time to put my hands on it, things seem to be working out well. more ideas never hurt, though.)
1974 Jimmy- 5.3/4L80e/NP241
Old 02-14-2014, 10:39 AM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: Trans cooler ideas
Mine goes to coolier in radiator then to aux coolier in front of radiator then back to transmission. The 700r4 had over 100,000 on it like this with no problems.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-14-2014, 11:10 AM   #3
Matt Cramer
Factory cooler in the factory radiator (and the factory TH350 transmission).
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 02-14-2014, 12:23 PM   #4
mooseknuckles
mooseknuckles's Avatar
I have this mounted under the bed, because I didn't want those ugly tranny lines visible...
mooseknuckles is offline   Reply With Quote
Old 02-14-2014, 12:38 PM   #5
Jonboy
Moose, what cooler is that? I think I might be able to make something like that work.
Old 02-14-2014, 12:53 PM   #6
mooseknuckles
Derale...think I paid $140
http://derale.com/products/coolers/t...ler-kit-detail
Old 02-14-2014, 01:23 PM   #7
ls1nova71
ls1nova71's Avatar
I have both factory coolers, trans to radiator to auxiliary and back to trans. I personally wouldn't try a heat sink kind on an overdrive as they produce more heat than a non overdrive, but that's just my opinion.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-14-2014, 01:47 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I didn't have the option to run through my radiator, so I run the same type of cooler as Mooseknuckles. Mine is flat-mounted in between the front frame horns tucked in the bumper. The fan feels like it moves as much air as my regular e-fan, and the draw hasn't been crazy. I like being able to idle or stage and have my tranny cooled the whole time.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-14-2014, 02:04 PM   #9
Jonboy
Thanks for the link. It is on the way now.
I liked the idea of the heat sink cooler, but wasn't sure how well they worked. The Derale looks like it is going to work perfectly. My original trans likes were already ganked by the ham hands that put the 350 in the truck. I think I have most of their engineering cut out (replaced with my own- better or worse).
Old 02-14-2014, 02:39 PM   #10
mooseknuckles
Mines been on there for a couple summers now, and seems to be working fine...you can hear the fan come on in traffic and it runs for a bit and goes off, so it's definitely keeping up....
Old 02-14-2014, 03:15 PM   #11
Wasted Income
Boosted Member
Wasted Income's Avatar
Here's mine.
The silver colored one is my engine oil cooler, and the trains oil cooler is a Derale stacked plate setup. Keep my junk cool, with a 3400 stall converter.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-14-2014, 06:38 PM   #12
mrhurt73
I got the same one mounted under bed, behind rear axle.
My Projects-
http://67-72chevytrucks.com/vboard/s...d.php?t=557301
Quest for Hot Rod Power Tour 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=543735
my 85 GMC 2wd to 4wd conversion for the wife.
mrhurt73 is offline   Reply With Quote
