02-14-2014, 11:15 AM | #1 |
street demon 625 carb?
what do yall think about the street demon carb? im looking at the 625cfm model with vac. secondaries. wondering pros, cons of this carb im running a mildly built 350 with 700r4 trans. i see the kickdown cable is integrated into the linkage, but what about the bracket that holds the cable in place? sold separately? cant find that piece. looking to replace a holley 4160 carb. good idea or not? just lookiong for some input, seems everywhere i look people are saying good about it
02-14-2014, 12:04 PM | #2 |
Re: street demon 625 carb?
I'm interested in this to. My holley is starting to leak and the demon body is supposed to more resistant to fuel leaks.
1971 Chevy C10 Cheyenne (sold for Mazda) 1963 Chevy Corvair Pro-Touring Project 2012 Mazda 3 i Sport sedan http://www.dracoautodesigns.com/ |
02-14-2014, 12:26 PM | #3 |
thats what they say. if im not mistaken they have a secondary air flap that is one piece or something like that. i know a guy that runs a similar motor to mine in his 32 ford and he said going from a edelbrock the demon was like fuel injection, he bolted it on and never looked back. thats hwat im interested in, how well they run. worth the 330$ a guy just offered to buy my 4160 and ive always been interested in the demons so i figured itd be a good time to upgrade
02-14-2014, 12:32 PM | #4 |
The main benefit is the body design. It only seperates at one point which is above the fuel bowls. Therefore there are much less gaskets for fuel to leak through.
02-14-2014, 09:08 PM | #5 |
Barry Grant has been out for awhile. Holley bought them and it's now their cheap carb. What that means is if you take either out of the box and put it on, the Holley will beat it hands down.
The old Demon carbs, if you get your hands on one it will be great, new ones not so much |
02-14-2014, 10:02 PM | #6 | ||
"I ain't nobody, dork."
All carbs will leak eventually. No matter what brand or model.
I would replace the 4160 with another 4160. I think you would be disappointed from switching from the Holley to that new Demon thing. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
02-14-2014, 10:38 PM | #7 |
I am not sure how you could consider a demon a cheap Holley since the demon is based on the thermoquad design. Plus the demon is no cheaper then a Holley price wise. I know that it will eventually leak and don't get me wrong I really like the Holley I have on my truck. But every write up and article I have read on the demons says that they are easy to tune and are heat and leak resistant compared to a standard carb due to the design of its main body.
02-14-2014, 10:53 PM | #8 |
I had a Demon about two years ago and I had issues, Idle adjustment and sticking floats. Could have been a lemon but...
I now use QuickFuel carbs (Holley copy's with all the good Holley extra cost features included). 4 idle circuits, bowl fuel level view ports, reusable gaskets, dual pump, coated for fuel corrosion protection. And so far no issues on both I own.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
02-15-2014, 12:43 AM | #9 |
I have the Street Demon 625 on my truck and like it a lot. I ran it on my old 327 for a while and it is now on my 355. Very easy to tune, essentially the same as an Edelbrock (Carter), but seems to have most of the inherent issues designed out.
Worked perfect out of the box on the 327, and required minor tuning on the 355. For my application I had to install a larger accelerator pump nozzle, put the accelerator pump linkage on its highest setting, and adjust the secondary air door opening. So far I have left the rods/jets/springs alone. I find it very smooth, great throttle response, huge kick in the pants when the secondaries open. Starts easy, idles smooth. They have a pretty decent manual and I've had good luck with their customer service. I called the tech line a few times while I was adjusting it. I had an Eddy 1406 before this, and gave up when I could never get a consistent idle. That carb was on the truck when I bought it, and I think it needed to be rebuilt.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
02-15-2014, 12:48 AM | #10 |
Also, FWIW----you can't compare the Street Demon 625 fairly to any Holley, or to the Demon carbs made a few years ago. Its very much an Edelbrock with many of the issues designed out.
I got mine on Amazon for about $275 by signing up for their credit card, so I figured for that price I couldn't go wrong.
02-16-2014, 01:28 AM | #11 |
Ive heard and read lots of good stuff about this carb as well. It seems to have great throttle response from everything I have read. I like the triple booster idea. There seem to be several naysayers about Demon carbs. I think this stems from Berry Grant days when QC went out the window. I would like to think now that Holley owns the company they would be more diligent about their finished product. Either way it looks like an interesting take on a street carb. Its as if a Quadrajet had a luv child with an Edelbrock who happened to be the grandson of a Thermoquad.
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
02-16-2014, 10:15 AM | #12 |
I didn't know about the 625cfm. I have a 670 waiting to go on my 327 when the truck is done. I think the 625 will be better suited. I've seen the Street Demons get better reports than any other carb commonly available.
02-16-2014, 11:00 AM | #13 |
I had thought the 625's were based on the old weber/carter design that had just a few problems like if you had much fuel pressure [like over6 or 7 lbs] it could override the needle and seat. The n/s's were bad about the sticking issue. Fuel pump regulators and a good type glass filter by the carb normally took care of most of those type problems for me on that type of carb, and if it has been redesigned it would be an awesome street piece. Jim
02-16-2014, 11:42 AM | #14 | |
the big thing they did is put an adjustable spring on the secondary air door so you can tune out the bog when the secondaries open.
02-16-2014, 12:56 PM | #15 |
Fuel regulators are worth their weight in gold,no matter what you run. can get by w/o,but way better with all around
02-16-2014, 02:50 PM | #16 | |
