whats the difference between a 68 and 69 radiator support?
on LMC they offer two different radiator supports for 67-72 trucks, so whats the difference? i am gonna order a bushing kit but dont know which one to get. i have a 68 frame but its different year support.
Re: whats the difference between a 68 and 69 radiator support?
There are 67/68 and 69-72 core supports. 67/68 core supports arm made for that grille. The headlights are spaced wider and there are mounting points for the splash pan. 69-72 core supports are all the same. You buy the core support for the type of grille/fenders/hood your truck has and buy mount bushings for the core support you are using.
Thanks. I guess my next question is how to tell them apart? I bought mine at a swap meet and only know it's a 67-72
69-72 will have a single light headlight bucket sticking off of it spot welded on each side. 67/68 will not have that, the headlights attach to the actual core support. This is huge to know, you can not "swap" them between the different front clips without some work (cutting/adding headlight buckets).
GMC's are different as well... have 4 headlights. Post a picture.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Small pic, but look at headlight area of my truck, you can see it's stamped out (part of) the core support for a 67/68. 69/72 will look the same but have an extra headlight bucket extension area spot welded on top of the bump out as well.
so this is a 69-72 correct? also if my frame is a 68 and radiator support is 69 which bolt and bushing kit do i need because LMC offers two different ones?
Yup 69-72. Frames were the same from 67-72 (with the exception of the steering box area on 67's). So you need the bushing kit that matches the core support... meaning you need 69-72 core support bushings.
Now, are you using a 69-72 Chevrolet front clip (fender, grille, hood?) because a 67-68 clip needs the 67/68 core support (you said the frame is a 68).
Thanks for the info. And yes all the front clip is 72.
