Old 02-14-2014, 02:47 PM   #1
eric8
Running R12 in a Sanden?
Hey guys...gonna be installing my ls3 soon so it will obviously have LS accessory drive with a Sanden style compressor. My 72 C10 currently has factory air that works great running R12 with the stock A6 compressor.
My question is, assuming I buy a Sanden unit already filled with R12 compatible oil and R12 charge ports, can I just get custom lines made and plumb the new compressor into my existing components, and continue running it as an R12 system? I figured this would be the cheapest/easiest integration into the AC system already there. Didn't want to go 134 because I'd like to keep the stock condenser, and I'm told 134 doesn't work too well unless you upgrade to a parallel flow unit.
eric8 is offline   Reply With Quote
Old 02-14-2014, 04:21 PM   #2
truckdude239
truckdude239's Avatar
Re: Running R12 in a Sanden?
Only problem i see is finding someone that can pull the r12 out and save it till you done r12 here is going for 96 dollars a pound makes 134a swap over look really nice.
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-14-2014, 04:49 PM   #3
hyatt
I did ac work for 30 years There is a product called freeze 12 Its a r12 substitute I used it for years instead of R12 performs the same If your sanden is for 134 change oil in compressor to old style oil
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 02-14-2014, 06:57 PM   #4
solidaxel
solidaxel's Avatar
I have some lb's !!!!!!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-14-2014, 07:52 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I sold a container of R12 for $475 when they banned it the first time here.
Two years later they said it was okay to sell hotshots, then banned them...
then came out with the replacements, and said it was ok again....go figure.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-14-2014, 08:22 PM   #6
eric8
Looks like you can still buy R12 on eBay but it ain't cheap! Regardless you have to sign an affidavit saying you are a reseller, authorized installer, or will have an authorized installer charge/evacuate the system you are working on before they'll sell it to ya. Suuuuure!
Old 02-14-2014, 10:21 PM   #7
Andy4639
Old member
Andy4639's Avatar
Wink Re: Running R12 in a Sanden?
The systemm will work but for the cost effictiveness I think your better off going 134-A now and be done with it. I can't tell any differance in performance of it compared to R12. Mine will blow 38-40 degree's sitting still.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-14-2014, 10:54 PM   #8
solidaxel
solidaxel's Avatar
YUP, he's right on both accounts, even here in the desert !!
LS 3 4L70E
Old 02-14-2014, 11:07 PM   #9
eric8
But to be sure, that is with the upgraded parallel flow condenser, right?
Old 02-14-2014, 11:14 PM   #10
solidaxel
solidaxel's Avatar
I still have the stock 1978 condenser and same evap. and R134 colder than the R12, I changed it 4 years ago, like it better
LS 3 4L70E
Old 02-14-2014, 11:42 PM   #11
eric8
Interesting! I may give the 134 a shot.
Old 02-15-2014, 09:14 AM   #12
Andy4639
Old member
Andy4639's Avatar
Yes mine has been upgraded. I bought the classic air upgrade when I got the compressor.
Old 02-15-2014, 06:20 PM   #13
lutronjim
Had a friend who ran a garage and he used freon called fr12. Compatible with r12 and was priced below r134. Don't know if its still around.
lutronjim is offline   Reply With Quote
Old 02-16-2014, 12:33 AM   #14
littlevictories
damn, lived in the PNW all my life
never even owned an A/C car
its all a buncha greek to me
littlevictories is offline   Reply With Quote
Old 02-16-2014, 12:49 AM   #15
eric8
Consider yourself lucky . Cause I'd love to delete the whole mess altogether and smooth the passenger side of my firewall!
Old 02-16-2014, 12:50 AM   #16
eric8
Hi I called it R12 earlier but that fr12 is exactly what mine had in it....They call it Freeze 12 I believe
Old 02-16-2014, 12:51 AM   #17
littlevictories
you're welcome to join us. just make sure your wipers are sorted and your windows dont leak
typically 180 days/year with precipitation this side of the cascades
Old 02-16-2014, 12:53 AM   #18
eric8
Yeah was gonna say what you give up with hot weather you get back ten fold in precip!
