Old 02-14-2014, 03:15 PM   #1
Aljohnsonii
Hazards don't work with headlights on
All my lights work but the hazards with headlights on if you cut headlights off they work anyone had this problem
Aljohnsonii is offline   Reply With Quote
Old 02-14-2014, 03:45 PM   #2
Aljohnsonii
1968 gmc hazards dont work with headlights on
all lights work hazards work with headlamp off when i turn them on the hazards stop working anyone had this problem
Old 02-14-2014, 05:08 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: 1968 gmc hazards dont work with headlights on
I would check all the battery to frame grounds, and add some if necessary.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-14-2014, 05:11 PM   #4
Aljohnsonii
I did that and changed the headlight switch it's just when I turn headlights on when they stop working
Old 02-14-2014, 07:29 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Re: Hazards don't work with headlights on
Most problems like that at ground related (or lack of). Read this thread.
http://67-72chevytrucks.com/vboard/s....php?p=4200642
LockDoc
Leon
Old 02-14-2014, 08:12 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Do the brake and rear turns work when the headlights are on? They use the same filaments as the hazards.
VetteVet
Old 02-24-2014, 05:21 PM   #7
Aljohnsonii
I redone all the grounds at turnsignals and still no turnsignal with light on
Old 02-24-2014, 06:00 PM   #8
Wrenchbender Ret
Try a different flasher. The voltage drop may be enough to cause it not to flash.
Wrenchbender Ret is offline   Reply With Quote
Old 02-24-2014, 09:20 PM   #9
Aljohnsonii
I sanded all the grounds and changed all fuses and bulbs the passenger side turn signal works with lights on but the driver side doesn't work with the headlights on and the flashers work with headlights off and don't when it's on
Old 02-24-2014, 09:28 PM   #10
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Do you have trailer wiring? If so, I suspect thats your problem. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 02-24-2014, 10:07 PM   #11
Aljohnsonii
No trailer wiring
Old 02-25-2014, 05:06 PM   #12
Aljohnsonii
This is what I have working :
Turnsignals with headlamp off both side front rear
Hazards with headlamp off front and rear
Parking lights work passenger turnsignal work with headlamp on
Don't work:
Driver side turn signal with headlamp on front or back
Hazards with headlamps on
What I've done :
Added ground to cab removed all lighting grounds and sanded and cleaned ground to tail light housings
replaced flasher relays
sanded fuse panel connections and changed all fuses
Old 03-02-2014, 07:59 AM   #13
Aljohnsonii
Don't work:
What I've done :
Old 03-02-2014, 12:46 PM   #14
LockDoc
LockDoc's Avatar
Don't work:
What I've done :
Do you have ground straps from battery to engine, back of engine to cab, engine to frame, frame to core support, frame to bottom of cab, frame to bed? All ground connections to bare metal? Is the small black ground wire still clipped onto the pinch weld behind the instrument cluster? (It should be on the bottom right hand side)
Couple of other things you might check is the bulb socket contacts. I had one that was rotated in the housing once and the socket contacts were shorting out on the base of the bulb. Also, unplug both headlights, turn on the headlight switch and try the turn signals and hazards again to see what happens. Report back.
LockDoc.
Leon
Old 03-02-2014, 03:46 PM   #15
Aljohnsonii
Ok I put a ground from bed to frame I didn't have one there because bed was bolted directly to frame metal on metal contact. I unplugged the headlamps and same problem hazards or driver turnsignals not working with head lights on
Old 03-02-2014, 03:52 PM   #16
Aljohnsonii
Ok have another thing I just noticed to ad also I turn the truck off leave headlams on and turn the driver turn signal on the flasher blinks/ clicks and the turn lights come on but don't flash. The hazards still don't work in this situation
Old 03-02-2014, 07:42 PM   #17
LockDoc
LockDoc's Avatar
What year is your truck? Are the turn signals in the bumper by any chance?
LockDoc
Leon
Old 03-02-2014, 07:44 PM   #18
Aljohnsonii
1968 gmc the lights are in the grill don't have the a bumper on it
Old 03-02-2014, 07:50 PM   #19
imjeff
imjeff's Avatar
Corroded headlight switch? It might have power out issues when it's in the headlight on position.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 03-02-2014, 08:15 PM   #20
Aljohnsonii
New headlight switch new dimmer switch and cleaned all the fuse holders
Old 03-02-2014, 08:36 PM   #21
kentucky_smith
I had a similar problem, changing the turn signal switch on the column cured it.
kentucky_smith is offline   Reply With Quote
Old 03-02-2014, 08:37 PM   #22
Aljohnsonii
I had hooked a new one up and it still done the same thing with the new one but I'll buy another and try it
Old 03-08-2014, 02:35 PM   #23
Aljohnsonii
I put a new turnsignal switch in the column and still same probl everything works until I turn headlights on then the driver side turn signals don't work and the hazards don't work if I turn headlight switch off everything goes back to working
Old 03-08-2014, 09:01 PM   #24
LockDoc
LockDoc's Avatar
I'm out of ideas. I'm still thinking it is ground or connection related though. What do you think of having the thread moved to the electrical forum to see if anyone there can come up with a solution?
LockDoc
Leon
Old 03-08-2014, 09:05 PM   #25
Aljohnsonii
I have one and no one responded
