Gear Install Questions
Hey All!
I have 3.08's in my '85 GMC 4x4. I'm running 33" BFG's, so needless to say, my truck has no power pulling trailers, or even going up hills for that matter. I'd like to step up to 3.73's, but have never installed gears before. I can build motors no problem, but haven't ever tried installing gears. I have a friend who has all the dial indicators or whatever you need. I was wondering if anyone has or knows of a place of a good technical write up to install the gears in the rear and FRONT differentials. I plan on putting new bearings and everything in there too. Josh |
Gentleman Jim Driver
I used the instructions available on the Randy's Ring and Pinion site. They are very comprehensive and very good. Read their entire tech tips section too, there is more info there.
I recently rebuilt my 12 bolt in my 84 with 3.73 gears and a True Trac, works like a champ with no noise. If you take your time and follow the directions to the letter, you CAN do it yourself. Be warned that 'all the dial indicators or whatever' are probably not going to cut it for tools, you really need the right ones. Here's a link to the Randy's guides: here and here.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
Right turn Clyde
If you always run 33s I would get something a little better like 4.11s even with 3 speed trans. Those are some pretty tall tires.
Sumit sell some videos on how to install gears. http://store.summitracing.com/partde...rt=RMG%2DVIDEO
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
I do always run 33's. Also, I have a 700r4 tranny. It seems like I always have to keep my foot WAY into the throttle when driving...even on flat ground...just to maintain 65-70mph. It also seems like every little slope in the road, my tranny kicks down since i have to open the throttle up so much. I'm thinking that all of this causes my 8mpg gas mileage. That seems horrible for a brand new crate 350, new edelbrock 1904 carb that's tuned, and a 700r4 with 3.08's and 33's. I'm thinking that by putting gears in, I can greatly decrease how wide open i have to keep the throttle while driving and that, in turn, will help my gas mileage. Does that make sense at all????
Project92 SWB stepside
I also have 33's on my 94 3/4 ton chevy. It has the 700r4 also. I talked to a gear guy today and he said run a 4.56 at a minimum. The gear for my truck is like $225 or more because it is a 14 bolt rear damn it!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
5 day ban, learn to behave.
yes 14 bolt FF gears might be a little more expensive but have you priced a detroit locker for it? cheaaaaaap. cheapest out of all other detroit applications
mike |
so do you think my "theory" about actually getting better fuel economy with steeper gears is true?
