Old 02-15-2014, 07:37 AM   #1
4DSEVEN
4DSEVEN's Avatar
Painting inner fenders - what did you use?
Looking for recommendations on what paint to use.
4DSEVEN is offline   Reply With Quote
Old 02-15-2014, 12:21 PM   #2
Highsider
Highsider's Avatar
Re: Painting inner fenders - what did you use?
My body shop is painting bed liner inside my fenders.
On the flat part of the steps, too.
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 02-15-2014, 03:19 PM   #3
crossfire84
crossfire84's Avatar
what he said.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 02-15-2014, 03:45 PM   #4
mr48chev
mr48chev's Avatar
I painted them to match the body on the last build but am still in the pondering stage this time. The reason being that last time it was an all out "street rod" pickup build with lots of aluminum and the matching inner fenders and painted bottom side of the hood matched the build but this time I am going for a build that "possibly" could have been done around 1957 by a custom shop and want things to jive with what would have been in vogue then.
I think Eastwood and some others have the proper no gloss black if you want to go that way or just use the same paint as you use on the body if you want to go body color.
My ongoing truck projects:
Old 02-15-2014, 04:18 PM   #5
4DSEVEN
4DSEVEN's Avatar
Agreed - I painted the inner fenders of the engine compartment to match.
I hadn't worded it right but was looking for ideas on the inside of the fender well itself (outer?). I was thinking of the Eastwood products but will definitely look into the bed liner option and go from there.
Thanks for the suggestions.
Old 02-15-2014, 11:53 PM   #6
_Ogre
_Ogre's Avatar
i think i used body color on truk
underside is rhinoliner bed liner
also bed liner on the bottom of the cab, starting 2'' below the vertical firewall
oem would be body color on firewall and black on inner fenders
shop air compressor timer
Old 02-16-2014, 05:39 PM   #7
dubie
dubie's Avatar
I coated the outside of the inner fender with POR15 waited for it to cure then scuffed it and sprayed some rocker guard material over top of it
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 02-16-2014, 07:40 PM   #8
OrrieG
OrrieG's Avatar
bare metal, epoxy primer, chassis black single stage, rattle can undercoating.Ooo
OrrieG is offline   Reply With Quote
Old 02-17-2014, 12:07 PM   #9
55metalmonkey
I did almost the same, POR15/ etching primer/ standard primer then top coat with bed liner. For the engine compartment side I did the same except for the top coat was the engine compartment paint vs bedliner
55metalmonkey is offline   Reply With Quote
Old 02-18-2014, 11:17 PM   #10
gag1025
We used bed liner inside the cab, under the cab, under the running board, under the inner and outer fenders.
1953 Chevy 3 Window Truck 3100 Series
gag1025 is offline   Reply With Quote
Old 02-18-2014, 11:52 PM   #11
G&R's57GMC
G&R's57GMC's Avatar
I'm getting mine powder coated . Wheel well side semi gloss black. Engine compartment side most likely the same, maybe.
I do like the matching paint look. Must be the Pentastar influence parked in the garage.
I also like the idea of bed liner on the step bottom in the cab. Another great place to use it would be the inside of the fenders and the firewall in the wheel well area.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 02-19-2014, 09:42 AM   #12
Highsider
Highsider's Avatar
Doing exactly that.
Powder coating sounds good!
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 02-19-2014, 10:32 AM   #13
gag1025
The reason I used spray on bed liner is to provide a soft cushion to protect the thin metal used in the body parts because when a rock is thrown up against those areas that I sprayed bed liner on there is a chance a small dent will be the end result. The bed liner will provide a cushion that will absorb the impact of the rock and prevent this dent. Hopefully the powder coating will do the same.
Old 02-19-2014, 10:33 AM   #14
dyno
dyno's Avatar
I was down at the auto body supply and saw they have a bedliner spray kit, with spray gun, 4 quarts liner and activator for around 125.00. looks like it can be hosed on to about 3/16" thickness from the sample I saw. I too will do the underside cab, cab floor and under fenders with it. I am thinking about doing the top of the cab steps with it and going over it with the body color. I'll have to check with the supplier to see if it's possible and practical to paint over the product.
"Built- not bought"
1958 GMC 150 4x4 in progress
1980 K20- Restored
1985 K3500 Flatbed
58 GMC 4x4 build thread:
http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675
dyno is offline   Reply With Quote
Old 02-19-2014, 11:02 AM   #15
55metalmonkey
Sounds like a raptor bed liner kit. Great stuff and be tinted whatever color you want. Just finished spraying it on the underside of my toneu cover and in the box and had it tinted the body color
Old 02-19-2014, 11:32 AM   #16
Angryman117
I coated the inner fenders with POR15 waited for it to be slightly stick to the touch, then put a coat of flat black on. Also doing the same thing on the inside and underneath the cab.
Angryman117's
47 Chevy Build
89 Silverado Z71 LS Swap (sold)
Angryman117 is offline   Reply With Quote
Old 02-19-2014, 01:01 PM   #17
OrrieG
OrrieG's Avatar
NAPA auto also has the same or similar in a roll-on product for better control and less overspray problems. I prefered the undercoating product on the inside of fenders, lower firewall and bottom of cab because it is "rubberized" and stays somewhat flexible. Inside of bed, bedliner is what I will use.
Old 02-19-2014, 10:01 PM   #18
Highsider
Highsider's Avatar
I am counting on the fender undercoat to cushion against the flying pea gravel on my new metal!
Regarding tintable bedliner, here is what my body shop says:
"WE CAN GET TINTABLE BED LINER .
I HAVE SEEN A LOT AND THE COLOR LOOKS LIKE YOU WERE
TRYING TO MATCH PAINT BADLY. COLOR CONTRAST I THINK
LOOKS BEST. BLACK IS SET OFF VERY GOOD BY OFF WHITE."
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 02-21-2014, 11:57 PM   #19
roger55
roger55's Avatar
Southern Polyurethanes (SPI) black epoxy primer for me. No topcoat necessary.
It's a semi-gloss and looks just like chassis black. Did my frame and suspension in it too.
roger55 is offline   Reply With Quote
Old 02-23-2014, 12:35 AM   #20
BigJackDaddy
BigJackDaddy's Avatar
I wanted to offset the darkness of the green with a contrasting, accent color on my '58. Although the grill and bumpers look white in these pics, they're really cream.
So I did the inner fenders the same when I had them off to help break things up a little:
ColoradoMelons.com
BigJackDaddy is offline   Reply With Quote
Old 02-25-2014, 06:26 PM   #21
MIKEs50Chevy
MIKEs50Chevy's Avatar
I had the engine compartment interior pieces powder coated in a gloss black. The outside of the truck is matte black, so it provides a little contrast and it wasn't any more expensive than having the restoration shop paint them. I like the durability factor too
MIKEs50Chevy is offline   Reply With Quote
Old 02-25-2014, 07:29 PM   #22
Dan in Pasadena
Dan in Pasadena's Avatar
Did you fill all the assorted holes in the inner fenders?
Seems like welding/grinding them shut will eliminate them, but will make uneven-ness be MORE pronounced under powder coating. Under paint at least you could use a minor amount of body filler.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 02-27-2014, 09:17 PM   #23
_Ogre
_Ogre's Avatar
whoa whoa WHOA!
who is this bigjackdaddy with a chopped viking???
IWANNAKNOWMORE
