Closed Thread
Old 02-15-2014, 04:14 PM   #1
VA72C10
VA72C10
VA72C10's Avatar
Project part-out 22"billet rims, wilwood,cpp, big block parts, cowl hood, etc
Prices listed include shipping unless noted. First I'll take it...asking questions doesn't place you in line. I will do my best to get pictures posted but it may be a while. Several of the parts can be seen in the link to the project in my signature. Local pickup preferred and will make a great deal if you want a lot of these parts. Shipping will likely take several days or even a week or more once payment isn't received due to my traveling for work often. I accept paypal (ONLY if fee is paid by buyer), money orders, or cash in person. These are also advertised locally and other places online
22" Raceline Deceptives. 22x8.5 22x10 with Two Nitto 265/35/22 and two 285/35/22 2800 shipped
Backspacing is 5.5" front on the 8" rim, and 4.25" in the rear on a 10" rim for maximum lip on the rear wheels. They are designed to just tuck in the front and rear. Rear will require the 67-69 narrower style rear with 5 lug conversion.
CPP modular 2" drop spindles (73-87 ball joints) with Wilwood calipers and 5x5 smooth 12" Rotors disc brakes 700 shipped
Big Block Power steering (Show quality restored Big block factory setup with pump, pump cover, lines, and brackets) and new power steering gearbox 950 shipped
Black restored seat belts with new webbing (3 pc set for bench seat) 350 shipped
Factory Tilt steering column restored with Perfect stock wheel painted semi-gloss black (Sold together only) 650 shipped
69-72 cowl hood new but out of box 400 NO shipping
67-72 new aftermarket doors with one piece windows installed in driver's side and most parts (missing triangle piece and lower mount for glass- have glass and scrapers- checking on ordering these parts next week) for passenger side. Power window regulators. 900 FIRM for everything NO SHIPPING
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline
Old 02-15-2014, 05:18 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Project part-out 22"billet rims, wilwood,cpp, big block parts, cowl hood, etc
1969 a/c cab shaved drip rails, rear seam, firewall, and gas filler hole Replaced outer rockers, cab mounts, and cab corners. Floor is solid. Inner rockers needed work but they put outers on. Also has one small spot above driver's side windshield 3" long that needs patched. comes with tx title. 1550 as is. NO shipping.
NEW doors with Brother's one piece windows with power window regulators. Needs a few parts to finish install on one door 900 for pair. 2300 for cab, doors with one piece power windows, and new door hinges.
swb roller frame with extra holes shaved (needs final grinding on some). Primered with etching primer. Was a leaf spring frame PO converted the right way to trailing arms with grade 8 hardware, CPP trailing arm crossmember, and CPP tubular trailing arms. Converted to 73-87 front crossmember with 5 lug discs. Still has 6 lug 12 bolt rear. Has power steering gearbox installed. Roller wheels/tires barely holding air. 850 NO SHIPPING
2200 for cab and frame together. 3000 for cab, frame, and new door hinges and doors with power one piece windows.
VA72C10 is offline
Old 02-17-2014, 03:53 AM   #3
54Caddy
GM Addicted
54Caddy's Avatar
willing to sell calipers by them selves if there for the thicker rotor?
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline
Old 02-17-2014, 04:50 AM   #4
bbbc10
Diggin The SquareLife
fingers crossed you still have the wheels when I get my income tax!!!
bbbc10 is offline
Old 02-17-2014, 09:51 AM   #5
VA72C10
VA72C10
VA72C10's Avatar
sorry, I want to sell that all together as a package.
VA72C10 is offline
Old 02-17-2014, 10:39 AM   #6
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Price for all of it except wheels and tires picked up? Whats the ratio on the rear end? Thanks, ~Michael~
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline
Old 02-17-2014, 01:21 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
I haven't pulled the cover on the rear so I'm not sure of ratio. I have another 6 lug rear---will try to look for codes but won't have a chance to for a week.
I'd do 3900 for the rolling frame/cab/new doors with one piece glass and power regulators/cowl hood/tilt column with wheel/restored belts
Add 600 for the wilwood/cpp setup for 4500 total
Add 800 if you want the restored big block power steering setup with it for 5300 total
Actually if you did everything I'd do 5000 even.
I do have someone local interested in the frame and cab so let me know as soon as possible...he's wanting to come down possibly this weekend.
VA72C10 is offline
Old 02-19-2014, 10:59 PM   #8
Ironangel
Ironangel's Avatar
I'll take the column..@ "$650 shipped"...Will you take $1200 for the column, the spindles, rotors, & calipers listed in this thread, "shipped?" I want the column shown & described in this thread regardless...PM your payment preferences...Thanks, ~Michael~
"Two Seventy Two's"
02 3/4 ton Express
Old 02-20-2014, 01:53 AM   #9
VA72C10
VA72C10
VA72C10's Avatar
I'd do the 1200 shipped for that. pm sent with payment info.
VA72C10 is offline
Old 02-20-2014, 03:41 PM   #10
Ironangel
Ironangel's Avatar
Ok, so that we understand each other...I'm getting the black rebuilt tilt column, CPP modular 2" drop spindles with(73-87 ball joints) with Wilwood calipers and 5x5 smooth 12" Rotors disc brakes all shipped for $1200? Will the Wilwood calipers work with the factory MC & Hydro-vac? If so, box everything listed here and I'll pay pal the money as soon as I speak to you on the phone to verify...Cool? Thanks ~Michael~
"Two Seventy Two's"
02 3/4 ton Express
Old 02-20-2014, 03:56 PM   #11
VA72C10
VA72C10
VA72C10's Avatar
Yes, that list is correct. Just confirming you are wanting the matching steering wheel as well? I do not see any reason they wouldn't work with that setup but I would recommend you call CPP to confirm. Everything is already boxed up ready to ship. feel free to call at your convenience.
VA72C10 is offline
Old 02-22-2014, 01:26 AM   #12
Ironangel
Ironangel's Avatar
$34.10 sent for fees...I owe you a buck...
"Two Seventy Two's"
02 3/4 ton Express
Old 03-02-2014, 11:40 AM   #13
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Payment for wheels and tires going out Monday. Thanks, Keith.
Down......with the sickness!!
crawdadfox is offline
Old 03-02-2014, 06:12 PM   #14
bbbc10
dang it I knew the wheels wasn't gona last till I got my income tax...guess gona have to get some smoothies
bbbc10 is offline
Old 03-02-2014, 06:56 PM   #15
Dirt_Baller
Do you have a arms for sale?
Dirt_Baller is offline
Old 03-04-2014, 03:27 PM   #16
Fast 82
I will take the doors! Thanks!
Fast 82 is offline
Closed Thread
