Old 02-15-2014, 06:09 PM   #1
gag1025
Radiator Overflow Tube Problem
The barbed fitting on the radiator is 3/8". The overflow reservoir (pictured below) has 1/4" fittings. I cannot find a metal 3/8" to 1/4" reducer to allow me to hook the overflow tubes up. Did any of you have the same issue? If you did, what was the solution?
1953 Chevy 3 Window Truck 3100 Series
gag1025 is offline   Reply With Quote
Old 02-15-2014, 06:52 PM   #2
Speedbumpauto
Speedbumpauto's Avatar
Re: Radiator Overflow Tube Problem
You force a piece of 3/16 or so vacuum tubing over the fitting and that acts as a bushing for the 3/8 hose. Ya might have to grunt a little or use some silicone but it will work and looks pretty good too.
Speedbumpauto is offline   Reply With Quote
Old 02-15-2014, 07:35 PM   #3
gag1025
Thanks Speedbumpauto. That is a great way to solve the problem. My question to the manufacturers of the overflow resevoir is why do you not use a 3'8" tube instead of the 1'4" tube that makes us have to make modifications when the simple thing would be to make things that fit.
Old 02-15-2014, 10:07 PM   #4
Speedbumpauto
My guess is that those tubes, except for the top, were manufactured for some other purpose and some entrepenurial type saw it and thought, with minor modification, it would be a great overflow tank that a profit could be made from. Unfortunately the mods didn't include resizing the tubes, only the screw on top.
Old 02-15-2014, 10:26 PM   #5
mr48chev
mr48chev's Avatar
Look outside the truck box http://www.hydroponics.net/i/139702 A local garden supply, irrigation supply or hydrophonics supply probably has them.
Or check Grainger if you want brass http://www.grainger.com/product/PARK...UH3?s_pp=false
If you live in farm country you might also check the farm equipment store that handles spray equipment as they usually have a big variety of small tubing fittings.
My ongoing truck projects:
Old 02-15-2014, 11:47 PM   #6
_Ogre
_Ogre's Avatar
when i manufactured this one i used 3/8'' tubes.
make your own, i have a couple bucks in this one
shop air compressor timer
Old 02-15-2014, 11:54 PM   #7
OrrieG
OrrieG's Avatar
Your wifes hairdryer on cooler setting helps make the "bushing" more flexible.
OrrieG is offline   Reply With Quote
Old 02-18-2014, 06:20 PM   #8
gag1025
All great ideas. Thanks.
Old 02-18-2014, 06:28 PM   #9
57chevyman
57chevyman's Avatar
I used windshield washer tubing and hose clamps.
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 02-18-2014, 07:11 PM   #10
55metalmonkey
1/4" to 3/8" barbed reducer. should be able to pick one up at the local parts store
55metalmonkey is offline   Reply With Quote
Old 02-19-2014, 08:22 AM   #11
fabguy
Elev8r Man
fabguy's Avatar
That's what I did. I ran it on both though. 1 to the radiator, and 1 just past the frame. I ran the second so just incase the tank over flows and the fluid is dumped out it won't get all over my engine and firewall. It won't stop it but the majority will end up on the road.
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
