Old 02-15-2014, 06:22 PM   #1
sigshooter
sigshooter's Avatar
Disappointed with fit of aftermarket fenders
About 2 years ago I bought a set of goodmark fenders, I decided to see how they fit today. I was told goodmark was good quality, but if these are good I hate to see bad.
They did not fit or line up around the header, and I had to do some grinding to even get them to slide into place at all.
I have a set of OEM off a 66 that need very little repair and I slid one of those in place and it fit like a glove. I will be repairing these OEM fenders and the aftermarkets are going on Craigslist.
I have heard nearly everyone complain about aftermarket and I have to agree with them
I will post pictures later today.
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 02-15-2014, 07:43 PM   #2
rideblue00
rideblue00's Avatar
Re: Disappointed with fit of aftermarket fenders
Yup bad stuff on the aftermarket. Fix OEM if at all possible!
rideblue00 is offline   Reply With Quote
Old 02-16-2014, 01:16 AM   #3
chevycowboy1985
Ya that sucks I keep herein that and will be fixing mine after read about this so much
chevycowboy1985 is offline   Reply With Quote
Old 02-16-2014, 11:14 AM   #4
62 Barnfind
62 Barnfind's Avatar
I bought two from classic parts. They were a little off from the originals. I had to work the fender and open some of the holes to make it work. I thought I was saving time by getting new fenders instead of repairing the OEM ones, but in the end it took longer. My next truck I will be using OEM fenders. I added some pics of mine on the truck after I lined them up. You can see where it's off a little. The average person can't tell so I went with it. I hope this helps you.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 02-16-2014, 12:00 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
Yep, they can be a rough fit. I modified every bolt hole and threaded insert just to get one side close. Then I decided, if I have to do this to the other fender, I might as well customize them...so, I did this:
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-16-2014, 12:06 PM   #6
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Hey guys...this is one thing I found out the hard way...1960-66 chevy fenders were the same style, but the bolt holes were all slighty in different locations. My '66's front fenders were toast, so I took the ones off my '64 and almost NO holes lined up..Yes they are oem fenders..but the bolt pattern looked darn near the same...but was darn near different from the pattern on my 66....In order for them to completely bolt up I am going to have to use the front panel from the 64 cause the holes line up...To sum up what I am saying...not all the factory trucks had bolt holes Exactly the same...I notice that some of the holes were almost 1 inch difference from the 64 and 66....So since aftermarket front fenders are made to fit 60-66 keep in mind that they will fit perfectly on some...but will need mild to extensive mods on others...
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 02-16-2014, 02:44 PM   #7
chevy2junk
chevy2junk's Avatar
I've delt with Taiwan parts in collision work for years as well as go parts.each have there issues.wich is easier trimming and slotting or cutting welding and bondoing.Maybe I'm missing it but from the photos they don't look bad.
chevy2junk is offline   Reply With Quote
Old 02-16-2014, 03:05 PM   #8
benwah
benwah's Avatar
I guess I'll be finding out soon. My 62 inner and exterior fenders were toast as well as the grill support. Only the hood hinges, hood, radiator support, and grill are original. As stated earlier they look good just need some tweaking. That's to be expected. I restored a 68 Dodge truck and noticed some body panels used off a same era truck built in another factory didn't line up well either.
benwah is offline   Reply With Quote
Old 02-16-2014, 11:10 PM   #9
pdxhall
pdxhall's Avatar
Just curious. Recently I have seen repop fenders from a supplier on ebay that claims the fenders are made from new dies and are a better fit and closer to originals. Does anybody have any experience with these. Sorry I don't remember the suppliers name at the moment.
I found it. The maker is AMD and claim to have their own tooling and are test fitted.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 02-17-2014, 02:33 AM   #10
Captainfab
60-66 Nut
I'm not sure just how long AMD has been around, but they have been advertising more often and getting magazine coverage lately. They do claim to have the best fitting and most accurately detailed aftermarket body parts. I have not yet had any of their parts in my hands.
Old 02-17-2014, 10:20 AM   #11
kieth
kieth's Avatar
We had the same problem, had 2 bad fenders that were original, cut them in half and put them back together, they fit better than the new reproductions.
here is a link showing how we joined the 2 together:
http://kieth.smugmug.com/Trucks/66-GMC/i-4zXvZkV
just click on the thumbnails after this picture to see the results. This fender is the right front on my truck.......new body parts suck !!!! Kieth
kieth is offline   Reply With Quote
Old 02-17-2014, 08:02 PM   #12
bama63
bama63's Avatar
amd is the best hands down, better fit,quality and thickness.haven't used any for our trucks yet but have on a few other cars and only needed the usual adjustments you may encounter with oem to fit well.
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 02-17-2014, 09:04 PM   #13
Roll'nSlo
Roll'nSlo's Avatar
After reading this I'm puzzled on what to do on my fenders. Going to replace left rear step fender.
Roll'nSlo is offline   Reply With Quote
Old 02-18-2014, 12:25 AM   #14
rustbucket66
I have a thread on here called "how do you fix this? - repo body parts", and it shows in detail the grief I went through trying to make aftermarket body panels fit. The shapes are ok, but anywhere there are holes or pieces spotwelded together, they aren't in the right places. Use the repos to cut up patch pieces for your oem panels and fenders.
rustbucket66 is offline   Reply With Quote
Old 02-18-2014, 02:31 PM   #15
61K10
61K10's Avatar
I bought 2 repo ft fenders one fit perfect and one was off (different brands) had to mod the rear mounting bracket some. also if off just a little you can sometimes move the cab a little to help. I moved my cab back 1/8 to 1/4 inch on one side. bought rockers from AMD and needed to mod some as well.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
