![]() Join Date: Jan 2014
65-66 Power brakes
Any of you guys gone with the Power brakes and kept drums and 6 lugs all the way around? If so... Any pointers?
Re: 65-66 Power brakes
Factory power setup and still drums... No problems here I love them.
I will probably switch the front to 6 lug disk one day, jut cuz I want to drive where ever I want with no problems!
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
Just make sure you upgrade to a dual master cylinder and split the lines to separate front from back. I used a distribution block(not a proportioning valve) from a '68 Camaro on mine. Some do not use one at all and have good results.
Just makes things a lot safer in case of a leak at either end. |
#4 | |
Thanks |
No I do not. The only pics we took were when I still had the single(original) master cylinder with a power booster. We changed that all out a month or so ago.
I have a 1967 C 10 master cylinder, a reman booster/bracket from O'Reillys, (made my own pushrod,) the '68 distribution block and ran all new lines to each front wheel. I removed the "T" on the passenger side that went to the RF and the rear, installed an inverted flare union to the line going to the rear brakes, and kept the line going down the passenger side frame rail, since that is where it is originally. Then extended that line across the front crossmember and up to the rear outlet of the distribution block. Doing it this way was a lot less plumbing. But, I was fortunate that my truck had a lot of new steel lines since the previous owner had rebuilt everything at one time. I highly recommend if you do not know how old that stuff is, to replace it, it's cheap insurance it'll work right and not fail. |
![]() Join Date: Aug 2008
I believe there is a sticky in the FAQ's about spiltting the lines. Also check into CaptainFab's bracket for the booster.
Mine are power drums..........I just added a 1977 booster and a 1967 dual master with slit lines..
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
60-66 Nut
![]() ![]() Join Date: Mar 2007
The first pics in my for sale thread for my '63-'66 brake booster bracket are of my '66 Suburban with power drum/drum brakes. The simplest way is to use a booster and master cylinder for a '67-'70 pickup.
http://www.67-72chevytrucks.com/vboa...=1#post3257836
![]() Join Date: Oct 2012
Here ya go. Power drums and lovin it. One of my fav upgrades. Final adjustment to the ratio made em perfect. They saved our bacon last week in the snowy weather traffic. I highly recommend power brakes
http://67-72chevytrucks.com/vboard/s...d.php?t=611577 |
| Bookmarks |
