need help ing.switch take out
can someone tell me how to take it out thanks bill
Half a bubble off!
Use a bent paperclip or something similar in the small hole to release the switch from the housing.
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
its all about the +6 inches
Insert said paper clip into the hole as you turn the key to the acc position. (counter clockwise) With a little wiggling and pulling, it should pop right out into your hand.
I know I know we have been through this before to no answer. The 68's dont turn CCW for the accessory position. What has anybody figured out on these?
Thanks Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
No idea.
thanks for the help guys
i have 67/72 chevy truck parts f/s. |
On 68's you put a paper clip in as instructed and turn counter clockwise about a quarter of an inch with the key installed and this will release the tumbler(there is no acc. position). You are physically moving the whole tumbler a quarter inch to get it past the tab which holds it in place. Works like a charm. Did it just the other day on a '68 ignition. If it won't budge try some penetrating oil around the edge of the tumbler, as some corrosion may have seized the tumbler in place. Good luck, Mark
1970 GMC Burb 4x4 - 68 Chevy Front, FI LT1, 4L60E 1970 Chevy Impala 47,000 miles 2001 BMW 540i 6-speed 2002 Dodge Ram 1500 4x4 w/20's |
Great Mark I will try it I hadnt spent much time working on it the post was up here a month or 2 ago without much success. I may try it tonight and will post the results.
Thanks Dave
