How Low Can I Go??
Looking to see how much I can safely lower my 1970 step side truck by only changing the springs.
I'm not into the real low riders but would like to lower my truck a little plus level it out. What can I do safely??? |
Re: How Low Can I Go??
Based on your statement I would say a 2-4 drop using coil springs front and rear would be safe and still very usable. This would slightly lower your truck and level it out.
What would be a good combination to lower and level?
2" lower in rear puts a truck pretty much level. 3" springs in front is the max,so 3/5 drop for lowest all spring and level. 5" is also the practical lowest for rear to maintain proper travel. Yes,you can "get away" with 6" but I said practical. 2/4 is a very nice look for those not hung up on way low. It improves handling and gives a pleasant stance without screaming out,"I'm lowered!". Subtle is always cool in my book.
CAN'T FIX NOTHIN
My truck is lowered 3" front 5" rear with spring's and in the rear it pulled the rear end to one side slightly , probly could have left it alone but I put an adjustable rear trac bar in mine cause ,,, well cause that's just the way I am LOL
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
Can you still haul 5 to 6 hundred pounds in a LWB with the 3/5 drop and still have enough clearence between the axle and the frame without a C notch?
I did a 2/3 drop. I like a small rake.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
#8 | |
CAN'T FIX NOTHIN
![]() No !
#10 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
So in your opinion a 2 1/2 Drop Spindle up front with a 4 inch drop spring would level a long box out nicely and give it that subtle look that I too really like. Would you need an adjustable track bar with a set up like that?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
![]() Join Date: Nov 2012
I'm going to bag the back on my truck. This allows me to haul a trailer, carry a load, and set the stance where I like, when I like, including when I'm loaded. I'm making an adjustable panhard bar and am only running individual schrader valves for now. All for the cost of bags and fittings and a little labor.
Then I can also lower it to the bottom for loading bikes, lawn mower, wheel barrows, etc. ![]()
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
Moderator
![]() Join Date: May 2007
This is the lowest you can go with a static drop, 5/7. It needed notching at even 5" in the rear.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#13 |
CAN'T FIX NOTHIN
My 3/5
#14 |
With a 3/5 spring and a adjustable panard bar, you will bottom out. I would use a combination of springs and drop spindles to keep as much travel as you can. The rear of my truck needs a C-notch. They make notches that you won't have to modify your bed. When I do get the notch I am going to two more inches in the front and rear. jmho.
Have fun. |
#15 |
Thanks everyone for your input, 2/4 sounds like what I want to do.
Does anyone out there have a pic of a step side with that combination? specks70 |
#16 |
the boat guy
4-6 no notch spring only drop. Is it right, no. Does it work, yes.
I couldn't imagine anybody running this setup and still using it as a truck. Lol Probably the same kinda guy who would haul wood with a swb and tow with gasp* peep mirrors.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#17 |
looks nice. Love it.
http://67-72chevytrucks.com/vboard/s...0&referrerid=0 |
#18 |
This is as close as I have for an example for you. This is 3-5 all springs. Custom made track bar to center rear end. No notch. Don't haul anything except my but, and I personally have not bottomed out any. Tires are 245/45/20 and are about 28.6 inches tall. I have plenty of ground clearance and I can drive this thing as I like with no worries. This is a little lower than you are asking for but maybe a good reference.
#19 |
Here is another.
#20 |
Wow 19GM71, I do like that. Very impressive. Good looking truck.
A question though. . . How would I know what length "track bar" I would be needing?? Last edited by specks70; 02-16-2014 at 09:33 PM. Reason: Incorrect question |
#21 |
CAN'T FIX NOTHIN
The length of the factory trac bar holds the rear end in line right to left stock height , when you lower the truck the trac bar will pull the rear end off center , the aftermarket trac bars are adjustable so you install it and measure your rear end to make sure it is centered easy as turning the bar left or right ,
#22 |
Thank You 19673ontree, I understand now, I guess I had some what of a stupid question and realized it once I posted. Thanks again.
I do believe that I'm going to move forward with the 2/4 combo. And am actually looking forward to it. I still have a long ways to go before my truck is complete so it may be awhile before even I see what it will look like with the shorter springs. |
#23 |
Not trying to highjack your thread specks70, I'm getting ready to do the same thing. Where's the most reasonable place to get all the springs and Trac bar that will be needed. Great question specks70, thanks for letting me highjack your thread for just a minute.
#24 | |
#25 |
![]() Join Date: Oct 2013
