Old 02-16-2014, 03:28 PM   #1
weider1717
Part help needed for rivets/pins on exhaust manifold
Hi, I am having trouble finding the correct part number for the exact rivet/pin on the right side exhaust manifold for my 87.
these rivets/pins (2) go on to help hold the "heat stove" or heat guard onto the manifold.
I am restoring the manifolds and tried heating the rivets/pins up but ended up just snapping one of the heads of the rivets off and stopped there and just going to take it to a machinist to drill them out etc.
anyone know what the part number for these rivets are? I am gonna need two new ones to put the heat shields back on. They're also spot welded together front side to back side around the exhaust manifold.
thanks for any help.
weider1717 is offline   Reply With Quote
Old 02-16-2014, 03:52 PM   #2
mrolds88
Re: Part help needed for rivets/pins on exhaust manifold
Don't know a GM PN, but this should help you.
http://www.rivetsonline.com/drive-sc...ve-screws.html
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 02-21-2014, 01:56 PM   #3
weider1717
ttt
Old 02-21-2014, 05:36 PM   #4
BONUSCAB
Pictures of these rivets?
Few things in life will make you look stupider than putting a dollar sign after a number.
BONUSCAB is offline   Reply With Quote
Old 02-21-2014, 11:13 PM   #5
Oldriginal86
Have you tried to use a small chisel and hammer to pop the rivet head up. Then use a pair of side cutter pliers to pry up on the head to remove.
Oldriginal86 is offline   Reply With Quote
Old 03-18-2014, 09:44 PM   #6
weider1717
had a shop get the rivets out all is good but still need the rivets!
Old 03-18-2014, 09:54 PM   #7
weider1717
I THINK these will work.
http://www.heartbeatcitycamaro.com/s...d-rivets-1969/
