Old 02-16-2014, 03:30 PM   #1
88fordf150
88fordf150's Avatar
Bent Frame Horn
I have a bent frame horn on the passenger side. The front of the frame horn sits about 1" lower than the one on the right. Someone had tried to straighten before I got I got the truck. I'm thinking of cutting it off and using a hydraulic press to straighten it back out then weld it back on in the correct position? Do you think I'm on track with my plan?
Brad handshoe
88fordf150 is offline   Reply With Quote
Old 02-16-2014, 03:51 PM   #2
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: Bent Frame Horn
No, I would either take it to a frame shop and let them pull it or do it yourself but dont cut it off to do it..
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 02-16-2014, 04:00 PM   #3
mrolds88
Re: Bent Frame Horn
Take it to a shop. Shouldn't be that much and they have all the stuff to get it jacked back into shape.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 02-16-2014, 04:04 PM   #4
terry b
terry b's Avatar
Re: Bent Frame Horn
Why dont you come over and cut the frame horn off a extra frame i am going to scrap and weld it on in place of your bent one. The metal is stretched on yours and is going to have a buckel in it anyway unless you cut it.
terry b is offline   Reply With Quote
Old 02-16-2014, 04:07 PM   #5
1972RedNeck
1972RedNeck's Avatar
Re: Bent Frame Horn
I would think a lot more frame is tweaked.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 02-16-2014, 04:11 PM   #6
terry b
terry b's Avatar
Re: Bent Frame Horn
A bent frame horn dont mean a thing.
Old 02-16-2014, 04:47 PM   #7
88fordf150
88fordf150's Avatar
Re: Bent Frame Horn
I sent you a PM Terry. Thanks, Brad
Brad handshoe
Old 02-16-2014, 04:57 PM   #8
boynton
boynton's Avatar
Re: Bent Frame Horn
Look up different ways to splice it in but I would cut in a new one personally (I've done this before) I cut mine under the cab because mine was tweaked past the motor mounts. (I originally thought it was just the frame horn as well. Pull some measurements with a tape and you can figure out how bad it is.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 02-16-2014, 05:06 PM   #9
terry b
terry b's Avatar
Re: Bent Frame Horn
Brad left my phone number in reply, Give me a call.
Old 02-16-2014, 07:15 PM   #10
hugger6933
Re: Bent Frame Horn
Before making any final decisions take some measurements in"X" patterns starting with the cab mounts. Go under the cab if they measure the same do the same in the front from the front cab mounts to the core support mounts that will tell you how much it is short. Remember that tape reading will need to be added together then divided by two to give you the difference that it needs to move. Also measure the wheelbase on both sides to make sure they are close to the same, they should be pretty close to the same number although not exact. These simple tape readings will give you the same clues that a frame guy would start off with but they won't let you know that because they won't pull on your truck while your around. Before I had my machine I used frame guys half way across the state it could all be the same they might be sitting on their thumbs but if I brought them a frame to pull they might put it up on the rack but never start to hook it until I would leave. We [my dad and I ]always thought they didn't want to see how quickly a lot of pull were made. After I got my machine that just reinforced that theory. Jim
hugger6933 is offline   Reply With Quote
