Old 02-16-2014, 04:24 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Speed Warning Hook Up
Okay, the answer to this may be simple but I just cant figure it out. In the attached pic ( I bootlegged the pic from an old thread ) what or where does the speed warning white wire with the connector that is near the speedo connect to. I'm getting things together to install my speedwarning with tach and vacumn gauge in my truck and cant figure where that wire attaches.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-16-2014, 06:04 PM   #2
70shortfleet
70shortfleet's Avatar
Re: Speed Warning Hook Up
The white wire connects to a grounding pin on the back of your speed warning cluster and the red wire connects to fuse block. When you reach the speed you have chosen for your speed warning the speedometer needle grounds the circuit and makes the buzzer buzzzzz
70shortfleet is offline   Reply With Quote
Old 02-16-2014, 06:18 PM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
To add to what les said, the pin the white wire hooks to is only found on speedwarning dashes.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-16-2014, 06:36 PM   #4
Already Gone
Thanks guys. So by pin ( and this is the back of my dash ) do you mean the little brass/gold colored thing under empty bulb socket hole?
Old 02-16-2014, 07:01 PM   #5
leddzepp
Moderator
leddzepp's Avatar
Yes the white wire clips to it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 02-16-2014, 07:12 PM   #6
Already Gone
10-4 Now I got it. I think the hook up should be easy from here.
Old 02-16-2014, 07:15 PM   #7
TBONE1964
Cluster King
TBONE1964's Avatar
Your cluster looks great. Nice attention to detail.
Take care,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 02-16-2014, 07:27 PM   #8
Already Gone
Take care,
Tom
Thanks Tom, I bought it 2 years ago from Paul ( PT's 70 CST ) and am going to get it installed this Spring. It also has the vacumn gauge. I was going to get a Classic Instruments dash but when I saw this I figured this is the Grand Daddy of factory gauges and Paul did a super job with this one making it like new.
Old 02-17-2014, 06:34 AM   #9
Andy4639
Old member
Andy4639's Avatar
Talking Re: Speed Warning Hook Up
Here is the correct wire hooked to fitting on dash. No the wire doesn go to other side it's just the way the wire was laying.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
