Door jamb switches
What has worked best for dome light/jamb switches and lighting delays in the AD trucks ? I've reshaped a '99 surburban dome light fixture to fit the stock 51 location, and fit the '99s inside door marker lights into the lower door faces.
thanks, Don |
Old Heap Driver
Re: Door jamb switches
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
Thanks Bryan
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
OrrieG;6530168]I used these:
http://www.ebay.com/itm/2-DEI-8607-Pin-Switches- thanks, just ordered some - any ideas on a lighting delay ? Don |
I used these. I chose them because they require only about 1/8th inch of clearance between the door and jam. Also, these are double pole switches which I needed for the courtesy lights I used.
^ Them thar is what i am a using also ! work out real well
#8 | |
I used Dorman 85932 self grounding door jamb switches
theyre available at Pep Boys and many other auto parts stores ![]()
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
""Delay or Relay?""
I want to use a delay, keep the courtesy interior lights on a little while after the doors close - at wifeys request.....since she 'bought' the truck !@! |
http://www.revolutionelectronics.com/Dome_Light.html
its less expensive on ebay http://www.ebay.com/itm/GM-Chevy-Mop...4ade1e&vxp=mtr
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 Last edited by 57chevyman; 02-18-2014 at 10:46 PM. |
Surprised that for $60 you only get 2.5 seconds delay and no adjustment? Better be fast finding the belts and key hole....
#13 | |
I put a toggle switch in my dashboard so I ( or my passenger ), can easily turn on the dome light while the doors are closed. I probably could have used a black knob switch to match the wiper knob, but the toggle switch looks custom, like it might control something more exciting than the dome light LOL ![]()
#14 |
Which design of switch you use also depends on if you need to ground the circuit when the door is opened Which is what the switches that Brian, 57Chevyman and Russel showed or if you need to complete a hot circuit with the one that Orrie showed.
Most every older rig I worked on had the dome light switches going to ground. There was a hot wire running to the light and then a ground wire ran from the light to both doors so the circuit grounded when you opened the door or grounded when you used the switch on the light. If you wanted to run a hot wire to the pushbutton switch on the door and then run a wire to the light and then ground the light you would use a two pole in and out switch.
#15 |
![]() Join Date: Jan 2009
Donaldo, check out the DEI 528T. It's an adjustable timer relay that sounds perfect for your application.
1949/1954 with LS swap-yeah! http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos |
#16 |
The NAPA switches in my post are double pole switches. The contacts close when the door opens. The hot wire goes to one side of the switch and the other side goes to the courtesy light which is grounded through it's housing. They use push in bullet connectors.
#17 | |
http://www.remotestartexperts.com/dei-528t.html
#18 |
Originally Posted by chev3600
""Donaldo, check out the DEI 528T. It's an adjustable timer relay that sounds perfect for your application. And only $15... here is how it works, 0-90 second delay. http://www.remotestartexperts.com/dei-528t.html"" I had looked thru all the ads I found and guess I missed that one - I did find one made in Oz for about $16US delivered, and it's is adjustable 5 to 60 seconds. So we'll see if it's any good.... My '51 has a bulb location in the ignition switch mount, so I will use the delay for that and small courtesy lamps over the kick panels, the dome light can go off when the doors close. thanks for the help ! Don |
#19 |
Old Heap Driver
The DEI528T is a good reliable piece, I've used a few of them in various applications over the years.
