Old 02-17-2014, 12:11 PM   #1
Temple of Torque
ZZ454 Clutch Selection
Okay guys I need your expertise. I am installing a ZZ454 into my 72 C10 that was originally equipped with a 350 and a Sag 3 speed on the column. For now I am going to keep running the 3 speed and need help figuring out what clutch to use. From my research it appears the clutch is a 10 spline 1 1/8" and the flywheel I have installed is a factory gm which calls for an 11" clutch. Would this centre force clutch work....DF735552? As well will I need to change anything for the mechanical linkage? Thanks
Temple of Torque is offline   Reply With Quote
