Oil guage fitting
I've got more questions bout hookin this thing up. I've got my copper line, but I can't find a compression fitting that will screw into the back of my guage. I've been to local parts stores, NAPA, and through old truck books, can't find anything. Thanks for your help.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
Low69,
When I did work on my cluster, I damaged the compresson fitting....I took the old one off the metal line and NAPA found one in stock. I put it on and it fit perfect.
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
67-72 truck surgeon
While you have the thing apart, throw that dinky compression type line away and get a braided stainless line. For the money its well worth the piece of mind because they are so much more durable.
1969 Chevy C10 1993 Toyota Camry LE 1999 Ford F250 Super Duty 4x4 diesel 2008 Dodge Charger Super Bee 1953 International R182 |
i thought about getting a braided, but where can u get a fitting to fit a stock guage???? Got to be the right thread and end to fit in there and seal up
I had the same problem finding the fitting. I found them at my napa store . I bought a extra set. If you cant find any PM me and I will mail you some.
Sisyphus was my mentor!
![]() Join Date: Sep 2002
braided line 4ever!
i bought from summit a few -3 to 1/8 pipethread adaptors & some -3AN line with teflon tubing inside the braided (by russell) with the ends already formed on the end & it works great - you cant make super sharp bends with it BUT it will last a real long time & you'll never need to worry about a squirt of hot oil inside your truck....
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
I'll take the guage to a local parts show and see if I can figure out what thread it is. Passthebuck, the port in the block looks like 1/8 pipe, but the guage looks almost like a regular thread. I'll head to the parts shop and see what happens.
ok low69cst - i'm pretty sure your gause is pipe thread too- keep me posted.
