Old 02-17-2014, 08:16 PM   #1
Nodnarb76
Nodnarb76's Avatar
C30 springs on an R20 suburban?
The rear of my 87 suburban sags a little. Would installing a set of one ton rear leafs on my 87 suburban fit, and give it a little rake in the back?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 02-18-2014, 11:31 AM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: C30 springs on an R20 suburban?
I think the spring width's might be different on one ton stuff but not sure. Have you measured how much sag you have? An add-a-leaf kit might be the ticket.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-19-2014, 01:34 AM   #3
burban nate
C-30 springs would bolt in. But you would end up with probably 2 or more inches of lift plus an extremely harsh ride. I just finished adding one middle leaf on each side of my r1500 Suburban, and that netted me 2 inches plus it is much more firm.
Nate
burban nate is offline   Reply With Quote
