Old 02-17-2014, 09:13 PM   #1
MJG
1965 Chevy c30 1 ton Dually
I have a 1965 chevy c30 1 ton dually that I want to change wheels to a later style. It has 7.00-18 lock ring rims and tires. I bought a 1987 chevy 1 ton for parts and it has front disc brakes. The wheel studs on the truck is 1/2" and the 1987 model wheels use 9/16" studs. Can I get oversize 1/2" lug nuts to make up the difference or would it be better to ream out holes and put in 9/16" studs. The bolt pattern is the same, 8 lug. Next question is can I use the front spindals off of 1987 and convert to front disc, I looked under both trucks and the lower A arm are different where they bolt to the frame. I was wondering if upper and lower balljoints are the same. I am looking to the experts to help me out. Thank's
MJG is offline   Reply With Quote
Old 02-17-2014, 09:43 PM   #2
Bigru
Bigru's Avatar
Re: 1965 Chevy c30 1 ton Dually
Where's the pics?
1965 Short Fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=637478
1983 Short Fleet (Under construction for my 13 year old son)
2008 GMC Denali
2012 Harley Roadglide
Follow me on Instagram: Ru_django
Bigru is offline   Reply With Quote
Old 02-18-2014, 01:09 AM   #3
Captainfab
60-66 Nut
I do not know for sure if the '87 balljoints will press into the '65 lower control arms. I have not verified that, but it is possible it will work. The uppers should fit the '65 control arms. I usually change the entire suspension, crossmember and all. If your engine is out, it is an easy 1 day job.
