Junior Member
![]() Join Date: Jan 2014
Hood hinge spring removal
What is the best way to remove the hood hinge springs?
Re: Hood hinge spring removal
1. Grab a friend.
2. Drill a 1/8 inch hole in the bracket/hood where it attaches to the hood. You'll use this hole to align your hood when you reinstall it. 3. remove the 2 upper bolts on both hings. 4. You and your friend remove the hood. 5. Give your friend a beer. ![]()
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
I always found a big screwdriver did the trick. But be careful.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
opps I miss read your question. Have no idea how to take just the spring off.
![]() Join Date: May 2010
I used an engine hoist. I don't know if you have one. I wrapped a length of chain around the two tubes parallel to the floor with the casters on them and used a chain repair link (the kind that used a barrel nut) to connect the ends of the chain leaving a couple links free at one end. I put another repair link on the hoist hook. I then hooked one end of the spring on the top link and held the hinge in position so the other end of the spring engaged the first free link of the bottom chain as I pumped the ram. A few pumps to stretch the spring and spring and hinge separate. It helps to have an assistant to do this. Since I was reusing the springs, I left them extended, cleaned and painted them and just reversed the process after the paint on the hinges and springs thoroughly dried . It's simple, safe, and allows full paint coverage if you paint your hinges/springs. It's also a lot easier to do than trying to explain it.
Brake tools work. Same principle as taking brake springs off just more strength required.
![]() Join Date: Aug 2008
I bought a tool from lmc. It has a T handle and a hook on the end. Makes changing springs easy!
X2 on the LMC hook tool. Still, I needed someone to help me pull to remove old spring and install new one.
It's alsways something.....
![]() Join Date: Nov 2008
I use two ratchet straps between 2 poles in my shop. Just do the click-n-stretch, it only has to stretch the spring an inch or so and the hinge falls out. I do whatever I need to the hinge and then set it back in place and release the strap and its ez and no drama
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
That tool from LMC is worth ever bite of the $15 or so I payed for it. As big as that spring is I didn't want to chance it and I rarely buy those type of specialty tools.
Junior Member
Thanks everyone
I ended up having a local body shop do it for me. Cost me $15 I think. Well worth having a HEAD left afterwards.
#13 |
No, go down to a farm supply shop and buy a hay bale hook. That is what I used, very heavy duty and safer in my opinion.
#14 |
![]() Join Date: May 2007
I just use a large boxend wrench over the spring tip, and pull on the other end. It doesn't need to pull very far.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
#15 |
A piece of rope or cable, hold it with each hand and hook it over the spring. Pull...it gives you a lot of leverage .
#16 |
Eat, Sleep, Drive a Chevy
What he said ^
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
#17 |
Moderator
Pop your hood open just enough so you can reach in from the side. The spring will be stretched as pictured below. Use some flat iron shims, or washers, or coins to put betwee the coils. Slowly open the hood all the way up. The spring will try to compress (as shown in the second pic, open all the way), but the shims keep it stretched and the hinge "shortens" enough for the spring to be removed by hand. If you use a lot of shims they will even fall out, so put a towel on your inner fenders if they have nice paint
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#18 |
Moderator
Hood open all the way, spring compresses, but shims will prevent it from doing this. Once removed, it is fairly easy to flex the spring side to side by hand and the shims fall back out.
#19 |
Junior Member
Thanks leddzepp!
#20 | |
That's how I did mine. Except I used wrenches. To install them, I used a come along, and my tractor. Spring on the three point pin, and the come along anchored on the mow deck.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast! Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun. 1st BN 3rd MAR. '00-'04 ![]() |
