Old 02-18-2014, 01:00 AM   #1
C10wip
C10wip's Avatar
Radiator OK, plug not OK
I recently installed a new Spectra radiator, the CU161 version which fits and is slightly larger and presumably better cooling than the CU162. Also, it's cheaper at AutoZone than RockAuto, which is a little unusual.
Anyway, it comes with a bypass plug/cap hose clamped on up by the filler neck. After only a month, I noticed that this plug was already cracking at the end. Not good! So, I am replacing it with a Dorman plug which appears to be a lot thicker but I am still a little concerned. The Dorman plug is part of a set, number 02253 so you end up with 7 other odd plugs. The plug ID is 11/16". Has anyone found a sturdier plug or better way to plug this off?
If you have installed one of these radiators and used the original plug, you might want to check it.
1980 C10 Custom Deluxe, 250 L6, 3 in the tree.
C10wip is offline   Reply With Quote
Old 02-18-2014, 08:03 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Radiator OK, plug not OK
Why don't you have a resevior installed? The neck connections goes to the resevior. It's Texas. When it gets hot, the plug is going blow right off when you turn off the engine.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 02-18-2014, 08:24 AM   #3
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
He isn't plugging the neck. He's plugging the heater return hose connection. Some engines return to the water pump, some to the radiator.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 02-18-2014, 08:35 AM   #4
Katrina/10
Katrina/10's Avatar
All those bypass caps are made out of junk rubber. Your'e better off with a piece of heater hose with a plug in it.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 02-18-2014, 10:01 AM   #5
C10wip
C10wip's Avatar
Correct, the heater hoses return to the water pump and block so outlet this is "extra". I looked around some more and apparently this is a fairly common problem; supposedly the Dorman plug will last longer, a year or so but will give out. Kind of surprised there isn't anything decent ready made. So, I'll look for a small chunk of heater hose and something to plug it with. Thanks.
Old 02-18-2014, 01:09 PM   #6
Katrina/10
Katrina/10's Avatar
The best plug is a copper water pipe cap.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 02-18-2014, 03:57 PM   #7
ElGracho
ElGracho's Avatar
It would also be easy to plug the hole in the water pump with a real threaded pipe plug and return the heater to the radiator...
Joe
Old 02-18-2014, 10:40 PM   #8
C10wip
C10wip's Avatar
This water pump has a cast outlet rather than a nipple like I have seen on some.
So, I'll go with a plug - also from the plumbing section - a short 3/4" brass PEX test plug; this thing has ribs on it so it shouldn't slip out of the heater hose and shouldn't corrode. All for $1.53 at Lowe's!
The outlet is 11/16" and apparently it's better to squeeze the 3/4" hose down onto it than try to stretch the 5/8, if you even can.
Old 02-18-2014, 11:43 PM   #9
ElGracho
ElGracho's Avatar
Oh yeah, I didn't read the 250 L6 part. I have one of those also, I think all of the 250 water pumps have the cast heater hose return...
I'll shut up now.
Joe
Old 02-19-2014, 12:06 AM   #10
C10wip
C10wip's Avatar
Not at all, thanks for the help. I see my truck is also "super duper plain" ...
Old 02-19-2014, 12:10 AM   #11
ElGracho
ElGracho's Avatar
I thought my 85 was plain. 4.3, SM465 4 speed, no cig lighter and no dome light. But at least it has power steering and brakes and gages. My 84 has a 250, 3 on the tree (now floor shifted) no dome light, no lighter, manual steering (I added power) and manual brakes. That's how I came up with super duper plain.
Both were cheap and straight. The 84 is even rust free and the dents are on parts that unbolt.
Joe
Old 06-21-2014, 03:47 PM   #12
C10wip
C10wip's Avatar
Jschuder asked for pictures of the plug installed, and here they are. I used tensions clamps ( Corbin clamps ) because I had them from another vehicle, but I'm sure hose clamps would work just as well.
Old 06-21-2014, 08:15 PM   #13
y5mgisi
Second Chance Program
y5mgisi's Avatar
Im having the same issue so i'll have to do the same thing.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 06-22-2014, 09:11 AM   #14
gchemist
gchemist's Avatar
Nice plug!! I need bypass valve during the summer. Heat off the heater core is an A/C killer.
Old 06-23-2014, 09:14 AM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
I'm using the doorman plug,thought they were for the carb,thats why they don't last very long.
(one a year,they only last that long on the carb anyway)
i like the brass plug idea better,didn't see those
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-23-2014, 10:05 AM   #16
buddy_1
buddy_1's Avatar
I know the "VOICES" aren't real but they have some great ideas.
1978 GMC Sierra Classic C25
1983 Datsun 280ZX Turbo
1997 Chevy Cheyenne K2500
1999 Polaris Sport 400
buddy_1 is offline   Reply With Quote
Old 06-24-2014, 06:44 PM   #17
jschuder
jschuder's Avatar
Thanks for the pictures I got it all fixed up and no leaks I used hose clamps instead but like you said it worked just fine
Chrome makes everything run better!!!
jschuder is offline   Reply With Quote
