Old 02-18-2014, 08:37 AM   #1
FASTDYNA
79 Blazer factory tach PROBLEM ?
Just bought a 79 k5 THE TACH NOT WORKING ITS AT ZERO WHEN IGNITION IS OFF AND PEGS WHEN YOU START ANY SUGGESTIONS WERE TO START ?
FASTDYNA is offline   Reply With Quote
Old 02-18-2014, 12:09 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: 79 Blazer factory tach PROBLEM ?
I'd start with the ground and the printed circuit on back of the cluster, there might be something obvious.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-20-2014, 10:35 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
is it new to the truck,
pegs running or in start
it should zero when keyed on, not off(mine moves a little bit)
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-21-2014, 08:45 AM   #4
FASTDYNA
just bought truck goes to zero when you turn on key then when you start it pegs out all other gauges work fine
Old 02-21-2014, 10:28 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
can you see if it's got the right harness on the back?
does it go threw the firewall?
should be pink power,brown coil,black ground....
other browns are lights......
may have been added?,
is the cluster case sealed behind it?
how high does it count?
stock ign?
plug on the dist cap?
mine looked like this
John
Old 02-21-2014, 03:35 PM   #6
FASTDYNA
every bone stock 75000 mile original 1 owner truck
