Old 02-19-2014, 09:36 AM   #1
big d's red67
big d's red67's Avatar
4-Wheel disc brake help
I have wilwood D52 calipers front and rear on my truck, question is my rear brakes stay engaged after the first few times I hit the brakes like I have a line collapsed. I have replaced everything except for the hard line that runs from the front to the rear. I have a dual diaphragm 8inch booster, new master, disc/disc perportioning valve, braided lines front and rear. Any ideas as to what my problem could be?
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline   Reply With Quote
Old 02-20-2014, 08:25 AM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: 4-Wheel disc brake help
I'm not personally familiar with those parts but; is there an inside and outside to the pads? Once upon a time I put the pads on backwards on an old Mercury beater I had and it acted like that -- all was well until I hit the brakes then they would clamp down and stay that way.
If that's not it (or not possible with those calipers, etc.) then...
This is just off the top of my head but; if this isn't a common symptom that someone recognizes I would start by splitting the problem.
Step on the brakes a few times till the rears lock then take a fitting off and see if they free up. (this will be messy , of course) If they instantly free up (I'm guessing you have an idea how long they stay clamped until they free on their own now) by pulling the fitting at the proportioning valve then the valve is your issue.
If they don't then it is probably in the line, somewhere. I am assuming the symptom is the same for each rear wheel here.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 02-21-2014, 04:15 PM   #3
big d's red67
Just need to adjust the rod from the master to the booster.
Old 02-24-2014, 12:39 AM   #4
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Did that fix it ...... ? If so KooL .....!
ksbrktracer is offline   Reply With Quote
Old 02-24-2014, 08:16 AM   #5
big d's red67
Yes it did. Thanks for the help Tommy.
