02-19-2014, 11:18 AM | #1 |
So,, what else you got???
Frame rivet removal advice...
Hey guys, what are you all using to remove the big rivets that hold brackets and crossmembers to the frame? I do not have a torch but just ordered a Chicago Pneumatic CP7150 air hammer, hoping that will do the trick. Thanks, Fred.
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks.... Sorry, we CANNOT ship larger parts. Thanks.
02-19-2014, 11:25 AM | #2 |
Moderator
Re: Frame rivet removal advice...
Cut an "x" in the rivet head with a cut off wheel. An air chisel will do the rest.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
02-19-2014, 11:28 AM | #3 |
Cool. I will give that a shot. Thanks, Fred.
02-19-2014, 11:28 AM | #4 |
Punch dead center and drill a 3/16 pilot hole. Follow that with a 3/8" drill just past the depth of the rivet head and pop the head off with the air hammer. Makes really quick work of the rivets but you may run through a couple of bits depending on how many rivets you have to knock off.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
02-19-2014, 11:29 AM | #5 |
I grind the head to make a flat surface, drill the center shank then punch the shank out.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
02-19-2014, 11:32 AM | #6 |
Use a 4 inch grinder with a cutting wheel. Cut the head off and use a punch to drive it thru. Fastest way I've found.
1971 C10 - LWB shortened to SWB, welded in my C notch, reinforced trailing arms with 3/16 plate, new cpp 5" rear drop springs, 2" drop blocks, ece super panhard kit. Cpp drop spindles, 2 inch front springs, 5.3/4L80E I call it Bruce Banner.. |
02-19-2014, 11:34 AM | #7 |
Drill bits.. That is a whole other issue. Where is everyone getting GOOD drill bits anymore?
02-19-2014, 11:36 AM | #8 |
Fast is good....
02-19-2014, 12:00 PM | #9 |
i used a grinder and ground the heads off and used a air chisel to push the rest of the rivot out
02-19-2014, 12:03 PM | #10 | |
Still Learning
I used this method and the slot in the head method. I found it cleaner to just grind the head off flush with the frame and then cheapy HF air hammer the rivet out. Some of them, you have to use a BFH and punch to get them started. I like the drilling method mentioned here too. Although I was lucky and didn't have to drill any of mine.
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 02-19-2014 at 12:45 PM. |
02-19-2014, 12:05 PM | #11 | |
1972 cheverolet K5 CST Blazer 350/auto/AC/PS/PB/Aux Batt From Medford, Oregon |
02-19-2014, 12:11 PM | #12 | |
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
02-19-2014, 06:16 PM | #13 |
Guys, I appreciate all the tips. Hopefully I can try them out this weekend, weather permitting. Thanks, Fred.
02-19-2014, 07:44 PM | #14 |
Laid Back
Snap on air hammer no need to drill or grind... Knocks the heads right off..
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
02-19-2014, 08:05 PM | #15 |
This^^ Except hammer is "long throw". BAP-ting !
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
02-19-2014, 08:51 PM | #16 | |
I only buy bits in packages of 12 and usually get "aircraft type, screw machine length" because they have a split point for easy starting and the stubby length is more difficult to break. Try Rex Supply, McMaster-Carr, etc.
Gale Gorman '54 3100 '67 C20 stepside |
02-19-2014, 09:05 PM | #17 | |
02-19-2014, 09:10 PM | #18 |
it is kinda soft i used a sharp cold chisel and a bfh on some of them.
the trailing arm brackets on the c member were a bear to get too but this method worked great. oh and of course a good punch afterwards too knock it out.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. Last edited by midniteblues; 02-19-2014 at 09:19 PM. |
02-19-2014, 11:46 PM | #19 |
my tip to you would be, don't take the head off and then use a Pointed center punch. it expands the rivet, use a flat head punch...ask me how i know...
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
02-20-2014, 05:53 PM | #20 |
I think I can probably guess....
02-20-2014, 07:45 PM | #21 |
Air hammer ftw.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
