02-19-2014, 12:53 PM | #1 |
Is this where I tap in for oil pressure?
I was adding oil to the engine, and it started pouring out this hole. After some searching I can't tell for sure if this was a return from an external filter, or for the oil pressure gauge. I don't have an external filter.
It's on the passenger side, at the top of the head just above the #5 spark plug. |
02-19-2014, 02:13 PM | #2 |
Re: Is this where I tap in for oil pressure?
That is the bolt hole and the one next to it are for the coil bracket. It sounds like the hole made it into the valve cover area . Wrap a bolt with teflon tape and install it in the hole.
The square plug to the right of the coil bracket bolts is a good place to check for oil pressure to the rocker shaft. You could screw in a gauge there to monitor while under the hood. On the other side of the engine down low you'll find another plug in the main oil galley this is a good place to mount a oil Pressure sender for the gauge in the cab.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
02-19-2014, 02:55 PM | #3 | |
02-19-2014, 04:07 PM | #4 |
Very good. Thanks.
