Old 02-19-2014, 02:33 PM   #1
datguy
194 head
i want to start my inline six build and i need a 194 head, anyone know where i can purchase one? kinda hard to find one for me!
datguy is offline   Reply With Quote
Old 02-19-2014, 03:02 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: 194 head
ChevyII's came with 194's. You might try looking up their forums for sources.
Are you just trying to up your stock compression ratio on a 230-250 or 292?
google: 194 chevy inline site:craigslist.org
Old 02-19-2014, 08:27 PM   #3
gofastnut
gofastnut's Avatar
Re: 194 head
X2 on what Aerotruk asked.
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 02-19-2014, 10:04 PM   #4
gimmy 64
Re: 194 head
don't bother it is not worth it . it's like putting a 305 head on a 350. old school .
gimmy 64 is offline   Reply With Quote
Old 02-20-2014, 02:16 PM   #5
datguy
Re: 194 head
i have a 250 i want to get more performance out of it..
Old 02-20-2014, 02:34 PM   #6
aerotruk63
aerotruk63's Avatar
Re: 194 head
The 194 is a closed chamber head as the one you have now is open chamber.
A 4 barrel intake with headers and a performance cam will get you where you want.
Pistons from a 307 will work in the 250. Keep the same rods as their lighter, though small block rods will work as well. Head work is needed. You can have larger valves installed in a stock 250 head. Port dividers can also be fashioned. Machining out the center boss for the headbolt that passes through each intake runner.There is a ton of stuff you can do to get performance out of a six. The power in a six is all in the upper end so rev's are required to get you moving. I put a 3000 stall in front of my Powerglide.
That's if you have money to spend!
Old 02-20-2014, 07:54 PM   #7
gofastnut
gofastnut's Avatar
Re: 194 head
Datguy,
I agree with aerotruk on this. You'd be better off to do a few mods to the current head than put some money into a higer-compression, flows less cylinder head.
Jeff
C-10 Club
