Old 02-19-2014, 08:54 PM   #1
exploderjim
exploderjim's Avatar
Porterbuilt extreme rear
Selling Porterbuilt rear extreme set up, tubular transmission cross member, rear frame cross member.
Weld in notch welded in Blazer frame in picture. I will remove it and remove bridge assembly for shipping. sand blasted for painting but decided to stop the build. Trailing arm Cross member to be removed from frame as well.
Asking: $ 1,300 plus shipping
That's $800 less than PB plus shipping and no wait.
The Dropmember Rear Trailing Arm Kit includes the following:
-Weld-in notch assemblies with notch caps
-Bolt-in bridge assembly - outboard bag location
-Firestone F9000 air springs
-KYB shocks
-Weld on lower bag mounts
-Fully adjustable trac-bar
-Tubular adjustable trailing arm x-member - 2 piece drive shaft
-Tubular 1″ drop trailing arms with 2" blocks
-Lower shock bar assembly
-All mounting hardware
exploderjim is offline   Reply With Quote
Old 02-19-2014, 09:42 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Porterbuilt extreme rear
I am interested in the trailing arm cross member since it is for a two piece driveshaft, if you split this stuff up. Thanks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-19-2014, 11:41 PM   #3
budnikguy
budnikguy's Avatar
Very Interested! Little concerned with shipping cost....Freight or Greyhound possible? I have a business address at 92557, residence at 92508, and or have a Greyhound station in Riverside, CA.
Please lmk...
budnikguy is offline   Reply With Quote
Old 02-19-2014, 11:42 PM   #4
budnikguy
budnikguy's Avatar
Scott I have a couple of PB trailing arm crossmembers..can check if they are 2 piece drive shaft style..
Adam
Old 02-19-2014, 11:46 PM   #5
exploderjim
Forgive me but How do I even get a shipping estimate from greyhound?
Old 02-19-2014, 11:51 PM   #6
budnikguy
budnikguy's Avatar
duplicate post
Old 02-19-2014, 11:53 PM   #7
exploderjim
If I estimate 3 packages at 100lbs each package is $100. I can't see these weighing that much. so I would say under $250 via greyhound. Anymore than that I would cover.
Old 02-19-2014, 11:58 PM   #8
budnikguy
budnikguy's Avatar
You can get a quote on their web site....they take up to 100 pounds per package, and you enter, to and from, locations. Would be easy to wrap them in cardboard and or padding..and just tape it up. Would not necessarily have to box things
Old 02-20-2014, 12:22 AM   #9
exploderjim
Pm me what you think would be fair.
Old 02-20-2014, 12:43 AM   #10
budnikguy
budnikguy's Avatar
pm sent
Old 02-20-2014, 02:46 PM   #11
exploderjim
Sold pending payment
Old 02-20-2014, 11:51 PM   #12
82swb
82swb's Avatar
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
82swb is offline   Reply With Quote
Old 02-21-2014, 12:42 AM   #13
82swb
82swb's Avatar
Sorry, I was just inquiring about a part mentioned earlier in the thread. I didn't think you had to support the board to buy product from board members.
Old 02-21-2014, 01:31 AM   #14
leddzepp
Moderator
leddzepp's Avatar
You don't when you are buying a part from the OP of the thread. It's considered hijacking otherwise. If there is a part you are looking for or in need of, you need to post a want to buy ad by starting your own thread. In order to post a want to buy ad you must be a subscribing member.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-21-2014, 09:11 AM   #15
82swb
82swb's Avatar
Apologies all around.
Old 02-23-2014, 10:24 PM   #16
Hardesty454
Hardesty454's Avatar
if sale falls through Id be interested in a few of the items or all if possible. Thanks!
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 02-25-2014, 10:25 PM   #17
exploderjim
Sold
