Firewall/cowl grommet for the antenna lead?
Does anyone know where I can find the firewall/cowl grommet for the antenna lead? I have search all ends of the web; from near & far (LMC, Brothers, etc..) and I cannot for the life of me find one. I bought an assorted pack of grommet's from the local auto parts store but none of those worked. It's the one where the wire lead from the antenna feeds thru the firewall, not the gasket one that the antenna sits on the cowl. Please help.
"Now all I need is a shop to go with my shop vac!" ![]() |
Re: Firewall/cowl grommet for the antenna lead?
I haven't seen one of those either lately, though I haven't looked hard. One thing I could recommend is maybe pick up a fuel line grommet for the cab floor? Should be roughly the same size. Or you're going to have to get a solid rubber plug and drill a hole. Best of luck!
i've never seen a grommet , just some chaulk smeared around it
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
![]() Join Date: May 2010
Got mine in the junkyard for no charge. They usually come with new antennas also. It's not a common grommet. Someone on the parts board who is parting a truck might have one.
#5 | |
Actually, I don't know how savvy you are, but being in a forum I can make assumptions.. So, get all the measurements you can, hole diameter, wire diameter, panel thickness etc, and then, mcmaster Carr. You can find any size, even Mil-Spec. The downside?... You'll probably get a bag of 50, but it'll be like $10, and then you can share and distribute to the needy! Or sell for $4 each. My question, where do I find a cowl mount antenna for them?
