How do you know for sure, I have two sets which appear to be Camel Back but not sure. Please help.
Drive it like U stole it
this is what you are looking for. I found these at my buddy's junk yard . I was walking and tripped over them in the dirt.
71 custom 10 swb 72 nova ss 72 nova custom 87 s10 96 burb 94 camry 53 5 window 3100 |
its all about the +6 inches
post the casting numbers on here.
Not that they are any better that the new stuff...even the dirt cheap vortecs. |
the most common is 461 and 462
Formerly yellow72custom
The last 3 digits of the casting #'s will be:
461, 462, 492, 041, 186, and i believe 291 was also a casting number. The 492 and 186 heads are pretty desirable b/c they have accessoy holes for alternator and A/C brakets, while the others do not. And yes, camel hump heads aren't the best hi-performance heads out there, but i love mine. You can still use all the standard intakes, valvecovers, and pushrods for any SBC, and getting a rebuilt pair with a little porting work done is still a couple hundred dollars cheaper than a pair of Dart or World Products heads.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
![]() Join Date: Feb 2003
041's have the accessory holes also
041's are not double hump heads. 041's are the same as 040's. What's a set of 461X heads worth?
1967 Chevy truck, R1 racing seats, 4 point racing harness, 4/6 drop, primered blue, soon to be shaved, 350- 060. over, flat top pistons, Eagle rods, Edelbrock Aluminum heads, 1.5 Scorpion roller rockers, Lunati 515" cam, mallory ignition, Holley 750 double pumper carb, Built 350 turbo trans, 2500-2800 boss hog stall, 20 gallon aluminum fuel cell!!! |
You are right.....041's do also have accessory holes. Any head made after 1969 should have them. I am pretty sure Mortec.com listed 041 as a double hump head...even if they dont have the 2 humps on the end of the casting, they still are a 64cc closed chamber head, and some came with factory 2.02/1.60 valves.
461X heads are proably the rarest and most potent double hump head made....the intake runners are 10cc's larger than the standard 461 head...up from 150-something to 160-something i think. I dunno what they are worth though.......
What is it with Camel Backs! Are they the best or what?
Is the idea to put big heads on th 350 block? Very interested! Cheers |
Camel HUMP heads were good at one time, years ago. The newer stuff flows just as good and are more reliable. The Vortex flow the best.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
#11 | |
Is this what the stroker part of the deal comes from?
Or is it just one of the many heads you can use? Cheers |
#13 |
That was 100 !!
Anyone have good avatars! Cheers ![]() |
#14 |
Na, stroke comes from the size of the crankshaft (and determines how far the pistons travel up and down). The size of the ports and valves in the heads determines how much fuel and air they will flow, and compression pretty much determines how hard the combustion will be (like sticking dynamite in a brick)
#15 |
Cool Thanks
In a nut shell! ![]() ![]() ![]() Know of any good sites to find more info one this! Cheers Glug Glug Glug! |
#16 |
#17 |
I know now that I have a set of camel back heads, I will have them built and use them on some ptoject. You have been very helpful and it is that which makes the board worthwhile.
#18 |
I don't know how the pic will turn out, but I hope this helps?
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
