Old 02-20-2014, 08:55 AM   #1
Econman
Econman's Avatar
Recommendations for engine paint and exhaust manifold coating/paint??
I'm getting my engine back from the machine shops next week and want to get the paint ordered while I'm doing the assembly.
What suggestions can you give on brand/type that is the most durable and looks best? I'll be using Chevy orange and some semi-gloss black for pulleys, brackets and breather and silver on the exhaust manifolds.
Thanks in advance for your suggestions!
Econman is offline   Reply With Quote
Old 02-20-2014, 10:18 AM   #2
cherokeejohn
cherokeejohn's Avatar
Re: Recommendations for engine paint and exhaust manifold coating/paint??
Any of the name brand (Rustoleum) rattle cans available at Advanced, Auto Zone, O'Reily's, Etc.. are good enough as long as its Hi-Temp rated. The key to it all is in the prep. Sand,Media,Soda blast if possible, then degreaser the whole thing (pay special attn. to small crevasses, nooks & cranny's, etc... Then the Important part, Use a Prep-Solvent (DX330) that removes any and all residues, glues, sealants, and even oils from our own skin. It also leaves a coat of its own Adhesion Promoter that helps the paint stick to the surface and avoid any "fish-eye's" or separations. There is an assortment of "Prep-Solv's", and mix in additives you can use if you are spraying with a gun that will help a great deal, but they can be quite pricey also. I personally haven't had any problems using the Rattle Can method, and I am a Painter/Body Tech. Best of luck to ya. Hope to see some pics when its painted.
72 C/10, LWB, 5.7, Auto, with A/C
F.B.I = Full Blood Indian
Appalachia/Eastern Cherokee,"Tsalagi"
cherokeejohn is offline   Reply With Quote
Old 02-20-2014, 12:49 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Consider ceramic coating for the exhaust manifolds and zinc phosphate coating (Parkerizing) the pulleys (also works great for the door strikers, hood hinges, hood latches)
Old 02-20-2014, 01:33 PM   #4
Econman
Econman's Avatar
I appreciate the tips.. Where is the best place to find the ceramic coating and zinc phosphate? Any special prep, such as high temp primer for any of the above after thorough solvent cleaning?
Old 02-20-2014, 01:41 PM   #5
Bigdav160
Bigdav160's Avatar
When I was a dealer tech, I used to send my engines over to the body shop and the painter would epoxy prime and paint them with BC/CC
They stayed nice and shiny. Very easy to clean.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-20-2014, 02:13 PM   #6
leftybass209
leftybass209's Avatar
Plasti-Kote is said to have the most accurate Chevrolet Orange paint color. My engine doesn't have any flaking, bubbling, or issues. As far as exhaust goes, there's 3 options that I know of that have worked with excellent results, and I am on the fence of which one to choose as well. There is Calyx coating. It was developed for Corvette enthusiasts. It is NOT a paint, but rather a paste that you can rub on a dirty manifold, and it will look amazing. The downfall to that is it needs to be reapplied periodically. There is POR manifold Gray paint. That seems to last a very long time, but needs blasted manifolds to adhere properly. The same goes for Eastwood Manifold paint, which also lasts a really long time. Best of luck!
leftybass209 is offline   Reply With Quote
Old 02-20-2014, 02:36 PM   #7
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I use the Eastwood paint and had the manifolds cleaned at the radiator shop and they still have some rust coming thru. I will ceramic coat the next time.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 02-20-2014, 02:41 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I used (what was then for me) a local coating company: http://www.kaehr.com/ Search for someone local to you or you can mail parts to this place. The have a minimum $100 order (does a lot of parts) but you can send a pile of greasy hinges, pulleys, bolts, etc. and get back parts that look new. In fact, I had them re-do a set of NOS door strikers that had shelf wear. Even the used set of door strikers they did for me looked new - only the wear on the plastic block belied that appearance.
GM you can see some pics of phosphate coated parts on my K20 build thread linked in my signature below (see post #181).
Old 02-20-2014, 02:44 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I have used Duplicolor engine paint for the last 10 years with good results. Prep your block, by making sure that all grease and assembly lube is cleaned off.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-20-2014, 03:54 PM   #10
BrianG
BrianG's Avatar
[QUOTE=cherokeejohn;6535074] The key to it all is in the prep. Sand,Media,Soda blast if possible, then degreaser the whole thing (pay special attn. to small crevasses, nooks & cranny's, etc... QUOTE]
Question on that comment,
Is it okay to do such things to the motor once it is assembled? I would assume blocking off openings would be a must, but is it okay to sand blast and/or power wash an assembled motor, or are you just asking for trouble doing this?
BrianG is offline   Reply With Quote
