Bumps along the way
Well I have a few questions and going through the company I have available at this time for larger items such as sheet metal I was wondering has anyone made their own bed sills? 67-68 rad Coe mounts? Also has anyone found a cheap solution to moving the column shift to the floor? Seems at this point for 400+ dollars I might aswell buy a new 4 speed manual.
1968 Chevy C10 build - http://67-72chevytrucks.com/vboard/s...d.php?t=546713 Member of tailgate association of manitoba |
Re: Bumps along the way
Also what's needed for maintaining heat but deleting air conditioning?
If you want to switch your airboxes from AC to heat you will need to patch some openings and make some new ones in the firewall.
I have had the stubby bed cross sill made, not the taller ones though. Maybe check with Empire Sheet Metal. I have some extras of those too, is it for a metal or wood floor.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
I have a wood bed, and I'm guessing I'll have to go purely after market for just a heater system?
You have a/c now? Most people have just heat and want to add a/c but you could just use a stock heater box in place of the a/c box, you will just have to reconfigure the holes
No mine was a rats nest torn up rusted cracked you name it. And I figure if I want air Ill roll down the windows. I was thinking just buy some 1"x2" channel and use that and jerry rig the bed.
I dont think you will get away with that as far as getting a safety, you still need a defrost system. I have some heater boxes kicking around if you need a better one.
Cool and that's all I need it for is defrosters it's gonna be a summer driver
