Mounting Tahoe third row seats
Removed the bench seat brackets and attached 1.5" 1/8" wall tubing on the front with 1/8" angle on the rear to maintain the correct seat angle.
![]() The seats give more leg room and set the driver back a little more from the steering wheel. They are more comfortable compared to the bench seat. ![]() Pulled it back out so I can mount a Kicker solo-baric 10" sub in the center. I will fab a console around the sub so it cannot be seen. ![]() |
![]() Join Date: Oct 2012
Re: Mounting Tahoe third row seats
Hugh,
Like what you are doing. Printed it future use. Wonder if there is a standard tahoe color that would work with medium green(OEM 529) interior. |
![]() Join Date: Jan 2013
What year of tahoe, that looks awesome!
IIRC the seats fit a 2000-2006 Tahoe. I like these better than other late model seats because they are thinner, have a lower back, and integrated seat belts. These can also be found for around $150 in excellent shape vice $500-$750 for the others.
I'll have to do this too. Any ideas for a jump seat/console?
I haven't looked into that since I had no desire for a jump seat. I can tell you that you will have between 12-14" to play with depending how wide you set the seats apart.
My wife may be able to cover that spread without a......did I say that out loud?
![]() Join Date: Feb 2011
Awesome upgrade! Thanks for posting this.
MusicMan70 1961 GMC Suburban |
I was just thinking about doing the same thing using 88 truck buckets and a folding seat console. I'm in to see where this goes. Thanks for posting it up.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
