Old 02-20-2014, 04:14 PM   #1
Hugh Mongus
Plugs
Should I still be using the original type plugs if I have converted to HEI?
Hugh Mongus is offline   Reply With Quote
Old 02-20-2014, 04:16 PM   #2
vectorit
What?
vectorit's Avatar
Re: Plugs
Yep, just adjust the gap on them.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-20-2014, 04:36 PM   #3
Hugh Mongus
Re: Plugs
.045?
Old 02-20-2014, 05:29 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Plugs
Yep...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-20-2014, 05:30 PM   #5
Hugh Mongus
Re: Plugs
Thanks!
Old 02-21-2014, 02:23 PM   #6
burnin oil
Re: Plugs
You can still run the tighter gap without issue. Usually when you run higher HP or forced induction you close the gaps up. Those cools TV commercials you see don't actually show the truth. All the added stuff going on iside the cylinder affect the flame kernal in a negative way when compared to an open air gap outside the cylinder.
burnin oil is offline   Reply With Quote
