Old 02-20-2014, 04:58 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Help with install on Suburban carpet
I have a full set of gray carpet for my burb. I put down the back section because it's pretty easy with no padding at all. What kind of glue or adhesive are you guys using for the passenger section and the wheel wells?
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 02-20-2014, 05:04 PM   #2
vectorit
What?
vectorit's Avatar
Re: Help with install on Suburban carpet
I didn't use any adhesives when I put my carpet in.
The seats hold the front area in place, and the chrome strips in the rear area hold that section of carpet in place.
The wheel well and fuel filler bump, those pieces are held in by the side panels.
Regarding the rear area, I added jute padding.
The front areas, I installed Dynamat along with jute padding.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-20-2014, 05:10 PM   #3
5150
C10 Club Tennessee
5150's Avatar
Yea, I have dynamat or insulation down all over the floor throughout. I don't have the carpet hold down strip where it steps up to the back of the floor.
Bryan
www.gmtruckshow.com
Old 02-20-2014, 06:57 PM   #4
72MARIO
72MARIO's Avatar
The hold down strip for the rear area behind the 2nd row is very similar to a residential transition strip from carpet to vinyl .
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-20-2014, 07:23 PM   #5
vectorit
What?
vectorit's Avatar
X2 Pretty sure you could get this strip from a flooring place.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 02-20-2014, 08:21 PM   #6
5150
C10 Club Tennessee
5150's Avatar
What did you guys use to get the wheel well carpet to lay down?
Bryan
www.gmtruckshow.com
Old 02-21-2014, 08:31 AM   #7
72MARIO
72MARIO's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=616694
here a link that shows the hold down strips
2005 TAHOE DD
Old 02-21-2014, 09:41 AM   #8
pwdcougar
pwdcougar's Avatar
The PO of my blue 70 used spray adhesive to put the wheel well carpet right over the rust holes.
Spray or even brush on contact cement would work well I would think.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
