Old 02-21-2014, 12:49 AM   #1
Ozzy2013
Ozzy2013's Avatar
Questions ,Questions
So if you had a 2wd truck that needs power brakes ,power steering added and you have a big block to go in it..And you had access to a 4 wd frame and free axles transfer case and transmission what would you do?Just curious looking for some opinions i know ultimately its my decision just looking for some input. Labor is free.Thanks Oz
Ozzy2013 is offline   Reply With Quote
Old 02-21-2014, 01:34 AM   #2
vectorit
What?
vectorit's Avatar
Re: Questions ,Questions
It all depends on what you want.
Going from 2x4, to 4x4 is a big decision.
Are you into 4x4's?
There is a heck of a lot of variables to this question to just say "go for it", just to get power brakes and power steering...
If you are into 4x4 trucks, then this is something to maybe sink your teeth into.
If you are just looking for a few power options that the 4x4 chassis is offering you, then I would tend to think you are looking at this all wrong and maybe take a step back?
If it were me (because I prefer 4x4's), then I'd be entertaining the thought. But... I don't like big block 4x4's. How's that for a rub?
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-21-2014, 02:24 AM   #3
Ozzy2013
Ozzy2013's Avatar
Thanks for the input.Its going to be big block either way.The existing 2wd drum set up on the front would have to be changed too .And i love 4 wd like i say just hashing it around thanks.
Old 02-21-2014, 01:41 PM   #4
The easiest way to go 4wd is fond a 73-87 all rusted out (with a good frame) and swap your body on. If your 2wd had leaf rear suspension,that would be a plus. But,you would need all the cross members from a 4wd frame to install in your 2wd. Swapping a 67-72 body onto the later frame is way way easier and less technical.
Old 02-21-2014, 02:33 PM   #5
Ozzy2013
Ozzy2013's Avatar
It is rear leaf spring I have a few leads on 67_72 4wd frames .Thanks for the input!
Old 02-21-2014, 02:53 PM   #6
NobleSix
id give my two front teeth for a 4wd around here. in winter time, open ended 2wd is kinna like a 2 ton sled.
'69 c10 longbed granny 4spd 292 "Behemoth"
'67 c10 longbed granny 4spd 292 "Burzum"
some pictures of my work in progresshttp://photobucket.com/zaeea
R.I.P. Corey "Flattus Maximus" Smoot 11/3/11
You will be missed. Your sound lives on.
NobleSix is offline   Reply With Quote
Old 02-21-2014, 02:59 PM   #7
dbash
4X4.... no question about it. But only with the 4X4 frame because its 25% thicker/stronger....
Either way you have some nice options at your disposal.
http://67-72chevytrucks.com/vboard/s...d.php?t=509467
2008 Dodge 3500 Blue Tech
2013 Challenger SRT8 392
1972 Landcruiser Rock Crawler LS1
1969 4X4 Resto Mod
dbash is offline   Reply With Quote
Old 02-21-2014, 09:47 PM   #8
If you can get a 67-72 4wd frame you have an easy job ahead...relatively speaking
Old 02-21-2014, 10:10 PM   #9
Ozzy2013
Ozzy2013's Avatar
Thanks guys im a 4wd guy from way back i live in Md and we get a lot of snow.If i built a 2wd corner carver it would end up sitting in the garage all winter .I am going to make it nice but intend on using it as much as possible.Thanks for all the input i will find a 4wd frame and go that way .Oz
