07-22-2003, 10:47 PM | #1 |
How much drop?
How much would you guys drop this '70 Sub?
Thanks! Doc
1970 Sub C-10 - 350/TH-350/3.73 12-bolt Came home from the hospital in it & mine ever since. 1966 Catalina Ventura 2-door fastback 389/TH400 |
07-23-2003, 01:06 AM | #2 |
Rockers1/2"off the ground
Well if it was up to me i would lower it this much: But it all depends what you want to do with it. Rule of thumb - the lower you drop it the more things you would have to change.
1962 fleetside: bodydropped,shaved,bagged,custom 64 suspension,clear taillights,custom aluminum parts,rollin on 100 spoke player wire wheels. http://www.finelinedesignz.ca |
07-23-2003, 08:52 AM | #3 |
Mike
I don't have a way to post pics yet,but I have 2.5 drop spindles and 3" drop in the rear.It gives it a slight rake.I have 255/60 and 275/60 with no rubbing or hitting.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
07-24-2003, 10:29 PM | #4 |
That's a cool truck to do that to. Should be sweet when you are finished it.
07-24-2003, 11:48 PM | #5 |
Young truck fanatic
lets just say there would be scuff marks on the ground where i used to be
07-25-2003, 06:11 PM | #6 |
Doc, my vote is 4/6. Low enough to look killer, but not so much it's a pain to drive. I would recommend 2.5 spindles + 1 coil off the stock front springs & air bags in place of the rear coils (so if you load up the family [think Griswalds/Family Vacation] you can adjust the height for the extra cargo). Don't forget a front sway bar w/urethane bushings.
07-25-2003, 06:13 PM | #7 |
I wouldn't with anything too radical. Probably a 2/4 or a 4/6. This way you can get away with minor mods to the 'burb. (c notch for the 4/6)
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
