07-22-2003, 11:11 PM | #1 |
steering column wire ???
I have a new tilt column in and everything hooked up. even the horn works, but for the life of me I cannot find where the gray wire that is seperate from the bunch of wires (molded together) goes. any help would be great.
07-22-2003, 11:59 PM | #2 |
I think that is your indicator light wire . When you turn on your lights the bulb comes on below the indicator .
07-23-2003, 12:48 AM | #3 |
go bucks!
yup,you be right....spliced mine in w/ the headlight's.
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
07-23-2003, 07:27 AM | #4 |
cool
I was wondering the same thing. Is it the wire with the two pins on the connector? Wootdog
1967 C10 Got it back after three years Boy I sure missed Peppy 1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
07-23-2003, 07:37 PM | #5 |
member #16
The grey wire plugs into the fuse panel,for light.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
